- Thank you received: 9
g76-g33 error
- jlviloria
7 years 1 month ago #146297
by jlviloria
g76-g33 error was created by jlviloria
Hello,
I'm trying to thread on my lathe.
The machine executes the threading command.
but I notice the following the movement is not continuous, the advance goes to zero and then gives a value of 235mm / min on average. until you reach the programmed distance.
I have another lathe with linuxcnc and it executes the threading cycle perfectly.
The spindle encoder is 2500ppr with A, B and Z channel.
working with 5i25-7i77
What can generate this error?
- pl7i92
- Thank you received: 358
7 years 1 month ago #146332
by pl7i92
Replied by pl7i92 on topic g76-g33 error
we need more infos
what version are you on what system os
is it different to the older mashine
and can you please give the full g-code command you executing
7 years 4 weeks ago #146855
Replied by andypugh on topic g76-g33 error
Is the spindle scaling correct, and in the right direction?
Perhaps the system thinks that the spindle is turning faster than it is?
Time to create page: 2.583 seconds
