- Thank you received: 241
Strange behaviour M61 Qn and cuttercompensation
- MaHa
7 years 4 weeks ago #147109
by MaHa
Strange behaviour M61 Qn and cuttercompensation was created by MaHa
Because i need to do manualtoolchange sometimes at other position than at defined toolchange position, i use M61 Qn instead of M6. Works fine, mostly. Only this situation example:
Having a flute mill dia=12mm in spindle, next tool is dia=2mm, and cutter compensation will be applied. When reload file and M61 Qn is used for toolchange, it occurs an error in connection with G41/G42. Cuttercompensation does incorrectly recognise current tool in spindle, instead of changed tool. Is there a way to make M6 toolchange position variable, setable from Gcode, or get rid off this behaviour of M61 Qn / G41 G42?
- BigJohnT
- Thank you received: 994
7 years 4 weeks ago - 7 years 4 weeks ago #147117
by BigJohnT
Replied by BigJohnT on topic Strange behaviour M61 Qn and cuttercompensation
You may want to read the
M6
section of the documents for important information about what it does and does not do. While not stated in the documents I assume M61 works just like M6 with the exception of not moving anything.
JT
JT
Last edit: 7 years 4 weeks ago by BigJohnT.
7 years 3 weeks ago #147156
Replied by andypugh on topic Strange behaviour M61 Qn and cuttercompensation
Yes. I think that the point here is that both M6 and M61 require a G43 to apply the tool offsets and diameter.
- MaHa
7 years 3 weeks ago #147181
by MaHa
Replied by MaHa on topic Strange behaviour M61 Qn and cuttercompensation
I use tooltable, and G43 is always applied. I made a short .ngc file to demonstrate, only need to load and reload. Tools T12 D=12 and T2 D=2 needed in tooltable.
Comment/uncomment in line 30/31. Open file or Ctrl-R produces the error, when M61 Q2 used.
7 years 3 weeks ago - 7 years 3 weeks ago #147429
i wish there was a way to mark forum posts as "unread" or (better) for follow up.
Now I have read this, I can't unread it, but don't want to forget that I intend to look at it.
If nobody gets back to this within a few days please reply just to bump it back up the list, I think this sounds like it needs looking at.
Last edit: 7 years 3 weeks ago by andypugh.
- MaHa
7 years 4 days ago #148988
by MaHa
After this problem occurred again yesterday, i remember to bump it back up the list.
Time to create page: 0.733 seconds
