Custom M code in Python example?
6 years 11 months ago #149473 by cmorley
Replied by cmorley on topic Custom M code in Python example?
Glad you got it to work.
set_p works on the HAL system it's the same code as typing setp in HAL and has the same restrictions.
The hal[] = is from inside the component so the direction of the pins are opposite.
(you wouldn't write to the component's IN pin, nor read the OUT pin)
5 years 6 months ago - 5 years 6 months ago #206192 by tjtr33
Replied by tjtr33 on topic offtopic: remora documentation
Hello scotta,
I am waiting for 2 MKS SGEN L v1.0 pcbs to try your Remora module with linuxCNC. They use the LPC1769 so may work with Remora. Could you tell me how you made the diagram for linuxcnc <--> remora? This is in the E-Stop loop section. It looked like XOD but only similar.. Graphic documentation of Hal nets is an on-going interest of mine.
TomP
( tjtr33 )
Last edit: 5 years 6 months ago by tjtr33.
5 years 6 months ago #206230 by scotta
Replied by scotta on topic offtopic: remora documentation
Thanks for your interest in Remora. There are a few people discovering this project and have it up and running on printers and mills. I'm trying to keep up with features.
I like the graphical representation of HAL. An easy way of explaining how the "wiring" works. This is one of the great strengths of LinuxCNC but one of the hardest for people to get their head around.
Many applications are now using a node approach for work flows and I stole the colour scheme from DaVinci Resolve and drew it up in PowerPoint unfortunately. I'd love to see a graphical tool to create the HAL files. But beyond me I'm afraid.
BR
Scott
  • twoflowers
  • Visitor
  • Visitor
5 years 5 months ago #210631 by twoflowers
Replied by twoflowers on topic offtopic: remora documentation
tjtr33 wrote: Hello scotta,
Did you succeed with Remora on the MKS SGEN L v1.0? If yes, I'd love to hear how you did it. My boards did come with LPC1768, not LPC1769.
5 years 5 months ago #210651 by scotta
Replied by scotta on topic Custom M code in Python example?
Yes ,it would be great to add this board to the documentation. If someone has a working config.txt file to share that would be a start.
For the wiring I've started the documentation. Below should be the pining for the EXP1 connector on the board.
The following user(s) said Thank You: twoflowers, tommylight
Time to create page: 0.297 seconds
