Take more than 2 arguments for M100-199?
6 years 8 months ago #157921 by meloon
Does anyone know if there is a way for the M100s customized code to take more than 2 arguments?
6 years 8 months ago #157942 by meloon
Replied by meloon on topic Take more than 2 arguments for M100-199?
Also, does anyone know if it's possible to remap M100-199? For example, assume we did remap for M100, and in the remap function, we make it execute 'self.execute('M100')', will it now run the M100 file? I need a component that can take more than two arguments and at the same be able to control HAL pin values (the HAL pin values are for customized HAL components)
6 years 8 months ago #158007 by Todd Zuercher
Replied by Todd Zuercher on topic Take more than 2 arguments for M100-199?
No, custom M-codes can only accept up to two arguments (P,Q)
No, M100-M199 are not remap-able.
But you may be able to remap another M-code to do what you want.
The following user(s) said Thank You: meloon
6 years 8 months ago #158047 by meloon
Thank you so much for helping, Todd!
6 years 8 months ago #158752 by andypugh
Replied by andypugh on topic Take more than 2 arguments for M100-199?
meloon wrote: Does anyone know if there is a way for the M100s customized code to take more than 2 arguments?
nasty workaround:
M100 P[#1 * 10000 + #2] Q[ #3 * 10000 + #4]
Then use a modulo division in the M-code code.
The other suggestions are better.
6 years 8 months ago #158754 by Todd Zuercher
Ingenious Andy, I bow to your hacking skills. but yes a truly ugly work around.
Time to create page: 0.921 seconds
