- Thank you received: 267
Remap M8 and M9 how to change iocontrol.0.coolant-mist?
- anfänger
6 years 7 months ago #159351
by anfänger
Remap M8 and M9 how to change iocontrol.0.coolant-mist? was created by anfänger
Hello,
I have a mill and mounted my mist coolant on an moving arm, so it van be moved out of the way for tool change.
I can move the arm with custom M codes. Now I want to remap M8 and M9 but I wonder ho can I set the iocontrol bits to turn my coolant of? Or can I still use M8 and M9 in the scripts even when I remap it?
Thanks Patrick
Thanks Patrick
- bbsr_5a
- Thank you received: 106
6 years 7 months ago - 6 years 7 months ago #159402
by bbsr_5a
Replied by bbsr_5a on topic Remap M8 and M9 how to change iocontrol.0.coolant-mist?
as you say yu move by coustom Mcode
so nothing change
NO remap needed
its simply a ON/OFF event
and the movement is given by a USERMCODE
Change your postprocessor to implement Your USERMCODE
and use the M8/M9 as it is decided to
the UserMcode can call a NGC file that moves your arm
like wise
M160 (arm in Move)
M8 Coolent on
Coolent off
M161 (move Arm Out)
GERMAN:
das ist meist sache des Postprozesses Wasser An Wasser Aus jeweils davor einen User Mcode ausgeben
Arm Einfahren und Armausfahren
GEHT Auch mit einem Kleine Script zB python das vor jedem M8 ein M161 setzt und nach jedem M5/M9 ein arm aus M162
Nutze die erweiterunf durch UserMcodes um die sache deinen Gegebenheiten anzupassen.
so nothing change
NO remap needed
like wise
M160 (arm in Move)
M8 Coolent on
Coolent off
M161 (move Arm Out)
GERMAN:
Last edit: 6 years 7 months ago by bbsr_5a.
- anfänger
6 years 7 months ago #159408
by anfänger
Replied by anfänger on topic Remap M8 and M9 how to change iocontrol.0.coolant-mist?
Thanks for you suggestion this might me actually a quicker solution.
Cheers Patrick
Cheers Patrick
- Thank you received: 2181
6 years 7 months ago #159423
Replied by cmorley on topic Remap M8 and M9 how to change iocontrol.0.coolant-mist?
or use the HAL pin to start your arm moving process.
Chris
Chris
The following user(s) said Thank You: anfänger
6 years 7 months ago #159534
Replied by andypugh on topic Remap M8 and M9 how to change iocontrol.0.coolant-mist?
Or have the arm moved by coolant hydraulic pressure
Time to create page: 0.927 seconds
