G2 or G3
6 years 6 months ago #164961 by empireages
Replied by empireages on topic G2 or G3
It looks like your object is 2 b-splines. Perhaps this can interest you :
g5.2 g5.3
6 years 6 months ago #164979 by sm
Replied by sm on topic G2 or G3
Thank you. :) initially lines of this model were nurbes curves (created in Rhinoceros) , but I spent time converting them all to lines and arcs, so, gcode could be written.
G5.2/G5.3 are still experimental and I don't think I want to deal with experimental stuff. Plus, my program is already written to extract coordinates from rhino's file and write gcode for it as G1/G2/G3.
6 years 6 months ago #164984 by cmorley
Replied by cmorley on topic G2 or G3
linuxcnc it's self could be called experimental. Nurbs has been in for years with no complains that I remember - but nobody really knows how much it's used (which can be said about a lot of linuxcnc)
Chris
6 years 6 months ago #164991 by sm
True, Chris.
but in my particular case, I think G2/G3 is what is needed.
Perhaps I am wrong and I would love to hear other opinions, so, let me explain a bit.
The reason I decided to stick with G2/G3 is because these codes are for arcs. and according to linuxcnc manual (and how I understood it) it is better for small arcs. another words, when arc is getting closer to full circle, linuxcnc cannot guarantee the precision. In my case it is ok. the machine I have built is for flat application - it cuts out elements of mosaic out of hard/brittle materials (glass, natural stone). because of this, I realized (actually number of cuts told me this), that I have to chop lines and arc into pretty small ones, to find the balance between feed rate and ability to cut certain pretty hard materials like agate.
so, arcs in my files are very small and should be perfect for G2/G3. and those are relatively easy to program - all you need is end point and radius.
6 years 6 months ago #165182 by sm
This is what I came up with.
Please, let me know if anyone sees errors in this table or anything is unclear.
This browser does not support PDFs. Please download the PDF to view it: Download PDF
6 years 6 months ago #165192 by bbsr_5a
Replied by bbsr_5a on topic G2 or G3
What cam are you using VISUALMILL 20x there is a simple HOOK inside your gcode that outputs the Climb/conventional CRC ofset
Time to create page: 0.805 seconds
