M100 command with arguments
6 years 5 months ago #167412 by JesusAlos
M100 command with arguments was created by JesusAlos
Hi.
I would like to use M100 P0 and M100 P1 to set a bit 1 or 0.
I created a machine with two VCP buttons, one to set a parport bit to on and other button to set the same bit off, with command M100 P0 and M100 P1.
The topic here is, when I execute the bash with linux ./M100 P0 or ./M100 P1 the bit is set true or false correctly, but when do M100 P0 or M100 P1 on MDI or using the vcp buttons, the bash don't read the arguments P1 or P0.
Attach the machine. I'm on the V2.9.
Thank you.
INI file
[HALUI]
MDI_COMMAND = M100 P0
MDI_COMMAND = M100 P1
hal file
net mdi-cmd-00 pyvcp.btn-on => halui.mdi-command-00
net mdi-cmd-01 pyvcp.btn-off => halui.mdi-command-01
vcp file
<?xml version='1.0' encoding='UTF-8'?>
<pyvcp>
<labelframe text="">
<hbox>
<button> <width>10</width> <text>"ON"</text> <halpin>"btn-on"</halpin> </button>
<button> <width>10</width> <text>"OFF"</text> <halpin>"btn-off"</halpin> </button>
</hbox>
</labelframe>
</pyvcp>
bash file
#!/bin/bash
echo "ini"
if [ "$1" = "P0" ]
then
halcmd setp parport.1.pin-02-out False
echo "is 0"
fi
if [ "$1" = "P1" ]
then
halcmd setp parport.1.pin-02-out True
echo "is 1"
fi
if [ "$1" = "P1" ]
then
echo "is 1"
fi
6 years 5 months ago - 6 years 5 months ago #167449 by Todd Zuercher
Replied by Todd Zuercher on topic M100 command with arguments
I believe that your problem is that $1 will equal 1 or 0 not P1 or P0.
Your bash script for the M100 file could also be much shorter and simpler. Simply having this should work
#!/bin/bash halcmd setp parport.1.pin-02-out $1 echo "is $1" exit 0
Last edit: 6 years 5 months ago by Todd Zuercher.
6 years 5 months ago #167477 by JesusAlos
Replied by JesusAlos on topic M100 command with arguments
Thank you
6 years 5 months ago #167516 by Todd Zuercher
Does it work? I didn't actually test that.
6 years 5 months ago #167523 by JesusAlos
I just test it and doesn't work.
The problem is the data type.
We must to change from real to integer. So, works like this:
#!/bin/bash
INT=`echo "$1" | awk '{ V=$1+0 ; printf("%.0f\n", V); }'`
halcmd setp parport.1.pin-02-out $INT
The surprising is, the bash wich works with linux console, don't works with LCNC, and the bash wich works with LCNC, doesn't work with console command ./M100 Px.
Thank you.
6 years 5 months ago #167529 by Todd Zuercher
I was afraid that may have been the case. Glad to see you've sorted it. I think the difference is that Linuxcnc is passing the variable in the gcode not simply executing a command line.
Time to create page: 3.218 seconds
