G-code stalls
21 Jul 2020 07:49 #175308 by prochj51
G-code stalls was created by prochj51
I am generating G-code with Fusion360 and want to engrave something.
I prepared test file H.ngc which is supposed to engrave letter H.
But when I run it, machine just moves to the home position and then is hanging there.
LinuxCNC does not throw any error. It looks like it is waiting for some line to execute.
The other test files work fine, so does the hardware.
The tool is in tooltable.
So I suspect the gcode (attached) is wrong in some way but I do not understand it much.
Any help would be appreciated.
Thanks in advance
Jiri
  • Moderator
  • Moderator
21 Jul 2020 08:05 #175310 by tommylight
Replied by tommylight on topic G-code stalls
Just to be sure, do you have tool number 70 in the tool table ?
21 Jul 2020 08:31 #175311 by prochj51
Replied by prochj51 on topic G-code stalls
Yes, I do.
It notified me when I did not, I added it afterwards.
21 Jul 2020 11:55 - 21 Jul 2020 11:56 #175327 by prochj51
Okey,
there was a other problem with manualtoolchange component.
Last edit: 21 Jul 2020 11:56 by prochj51.
  • Moderator
  • Moderator
21 Jul 2020 12:15 #175330 by tommylight
What was it ?
Time to create page: 0.251 seconds
