Lathe pauses at N21
5 years 11 months ago #189687
Replied by andypugh on topic Lathe pauses at N21
If you are using the Axis interface you can select machine -> halmeter and watch the value of spindle.0.at-speed (or motion.spindle-at-speed in older versions)
(this is worth trying anyway, it is useful to know how to watch the HAL signals)
If it is showing "true" then that isn't the problem. If it is showing false then the simple (but not the best) answer is to add "setp spindle.0.at-speed 1" in the HAL file. But then the machine will never wait for the spindle.
If you are not using Axis then there will generally be a different way to load halmeter. If you can't find it then "halcmd loadusr halmeter" from the command line will always work.
The following user(s) said Thank You: Flyer007
- Flyer007
5 years 11 months ago #189692
by Flyer007
Replied by Flyer007 on topic Lathe pauses at N21
Showing "True" good idea though. Also great to remind me to play with the meter more.
- Flyer007
5 years 11 months ago #189697
by Flyer007
If I throw a G94 into line N21 then up the F to .5 I get movement, BUT I don't get a G0 retract move on Z 3 lines later.
5 years 11 months ago #189701
Do you have a spindle encoder?
What does halmeter show spindle.0.speed-in doing?
- Flyer007
5 years 11 months ago #189715
by Flyer007
no encoder, but we have a winner. I added in a "setp spindle.0.speed-in 100" into the HAL and have movement.
Still having no movement on the retract Z move though.
- Flyer007
5 years 11 months ago #189734
by Flyer007
Time to create page: 1.368 seconds
