- Thank you received: 10
M106 remap to M67
- ericg
5 years 2 weeks ago #223373
by ericg
Replied by ericg on topic M106 remap to M67
has this been resolved? I ask because I would also like to remap Lightburn code but wondered if it is possible to remap depending on the S value.
What I would like is that M106 S0 be remapped to M68 E0 Q0 and M106 S500 be remapped to M67 E0 Q(#<S>/1000),
I have tried reading the remap documents but it's a bit confusing for me at this stage.
Maybe one day Lightburn will have the option to do this in their PP.
thanks
Eric
thanks
Eric
5 years 1 week ago #223839
Replied by andypugh on topic M106 remap to M67
I am not sure that you can remap M106. That is in the M100-M199 range that is used for a traditional mode of custom command.
(And, as M100 and friends run an external execuatable I doubt that realtime performance is preserved)
The docs say "All M-codes from M100 to M199 are user-defined M-codes already, and should not be remapped." But if I were you I might be tempted to try it to see what actually happens.
- ericg
5 years 1 week ago #223840
by ericg
Thanks for the response Andy, I did read that so not sure if it would work either, but I made a work around by creating a bash script with 2 sed commands (been ages since I did any bash scripting)
FYI or anyone else reading this my bash script is
#!/bin/bash
sed -i 's/M106 S0/G68 E0 Q0/g' $1
sed -i 's/M106 S/G67 E0 Q/g' $1
I saved it as RunSED (no imagination)
made it executable chmod +x RunSED
and then run it with ./RunSED 'filename'
seems to work OK
Eric
#!/bin/bash
seems to work OK
Eric
5 years 1 week ago #223849
You can configure LinuxCNC to automatically run files through the filter before executing them.
linuxcnc.org/docs/2.8/html/config/ini-co...html#_filter_section
- ericg
5 years 1 week ago #223871
by ericg
Thanks, good thought, I have played with that before so will give it a go soon.
Time to create page: 0.358 seconds
