- Thank you received: 22
Tool Path Rounding Issue
- paulsao
5 years 2 weeks ago #223357
by paulsao
Replied by paulsao on topic Tool Path Rounding Issue
Thanks for your answer I am attaching the 2 G code and I am using the Plasmac post processor.
- MaHa
- Thank you received: 241
5 years 2 weeks ago #223425
by MaHa
Replied by MaHa on topic Tool Path Rounding Issue
The following user(s) said Thank You: paulsao
- paulsao
5 years 2 weeks ago #223426
by paulsao
Did you open it in qtplasmac?
- MaHa
5 years 2 weeks ago #223430
by MaHa
The smoothing version is impossible to load with linuxcnc, my cam is capable to display toolpath from external loaded files. but then failed to follow the displayed contour, as expected.
- phillc54
- Thank you received: 2100
5 years 2 weeks ago - 5 years 2 weeks ago #223433
by phillc54
Replied by phillc54 on topic Tool Path Rounding Issue
I tried loading both in QtPlasmaC.
noSmoothing.ngc loads fine
smoothing.ngc does not load, I get this error:
A 20% error is quite large, there must be issues with the PP. The second image on this post seems to confirm that.
forum.linuxcnc.org/20-g-code/42361-tool-...ssue?start=10#223425
Mon18 16:50 G-Code error in smoothing.ngc
Near line 26 of
/tmp/emcflt-frkj78uq.d/smoothing.ngc
Radius to end of arc differs from radius to start: start=(X54.4565,Y61.2711) center=(X46.5479,Y57.0455) end=(X47.9508,Y63.9894) r1=8.9667 r2=7.0843 abs_err=1.882 rel_err=20.9937%
Last edit: 5 years 2 weeks ago by phillc54.
- paulsao
5 years 2 weeks ago #223447
by paulsao
Phill what is the minimum supported error for linuxcnc to work fine, I corrected some tolerance values and I have error = 0.4% but still I still have an arc error
Time to create page: 0.173 seconds
