Bash M1## how to use the P word
5 years 1 month ago #220527 by my1987toyota
Replied by my1987toyota on topic Bash M1## how to use the P word
eg.  for case 100 i was successful with
case $1 in      100.000000)
Would you mind giving more context on what your code does?
5 years 1 month ago #220554 by MaHa
Replied by MaHa on topic Bash M1## how to use the P word
It's from the timestamp for logfiles, still in use.
When   M150 P100  is called,  somehow the case statement is matching only, when testing 100 as 100.000000
forum.linuxcnc.org/20-g-code/36148-times...ogfile-solved#128037
The following user(s) said Thank You: my1987toyota
5 years 1 month ago - 5 years 1 month ago #220557 by anfänger
Replied by anfänger on topic Bash M1## how to use the P word
There was a change in LinuxCNC a while ago, i think all the former integers are now float. To change this you need to work with float in bash or convert. You can do this in the Goode or in bash.
Last edit: 5 years 1 month ago by anfänger.
5 years 1 month ago #220569 by my1987toyota
Thanks guys. When I get a chance I will give that a shot.
5 years 1 month ago #220571 by my1987toyota
That unfortunately didn't work. I have a feeling I have misunderstood how the M1## bash system works.
if I enter this M170 in linuxcnc it works
#!/bin/bash
halcmd setp classicladder.0.in-50 true
exit 0 ;
however this M170 P01 code doesn't
#!/bin/bash
case $1 in
         01)
esac
exit 0 ;
their must be alot of things going on behind the scenes in linuxcnc that I can't
see,  know about,  or probably don't understand.
I do have a theory that I may need to come up with a hal component to make
use of the P## as a varriable and the hal component determines what pins
to switch high or low instead of it happening in the M170 bash command.
5 years 1 month ago - 5 years 1 month ago #220574 by anfänger
Run LinuxCNC from command line
And change the script to:
#!/bin/bash
echo „P:“
echo $1
case $1 in
01)
echo „case true“
halcmd setp classicladder.0.in-50 true ;;
esac
exit 0
There you should see what the P value is
Time to create page: 0.180 seconds
