how to make M7 (mist on) generate step pulses
- mikeT
09 Aug 2025 11:34 #333111
by mikeT
Replied by mikeT on topic how to make M7 (mist on) generate step pulses
Hello Andy,
Thanks again for your support.
Inputting "halcmd setp stepgen.4.velocity-cmd 40" from the terminal, while a session of LinuxCNC is cutting metal, works well and is so easy to do.
Now I can adjust (and optimise) the MQL flow rate on the fly, It also allows me to easily use different flow rates for both neat synthetic fluids and also water soluble coolant.
It would be cool to control the flow rate from a virtual slider pot on the AXIS virtual control panel, but I suspect that would be well above my 'pay scale'
Thanks again
Mike
Thanks again
Mike
- Thank you received: 4149
09 Aug 2025 11:49 #333113
Replied by rodw on topic how to make M7 (mist on) generate step pulses
You can do it! It will depend on you GUI. some may even have the ability to program a slider. Have a browse in the linuxcnc docs as its all documented
- mikeT
10 Aug 2025 15:34 #333167
by mikeT
Can you help with how to control the flow rate from a virtual slider pot on the AXIS virtual control panel.
Mike
Mike
10 Aug 2025 16:07 #333172
Replied by andypugh on topic how to make M7 (mist on) generate step pulses
I don't normally recommend PyVCP as it is not very flexible, but in this case it is probably a good choice.
linuxcnc.org/docs/stable/html/gui/pyvcp.html
The example panel in section 4.1 is very close, you would just swap the bar for a slider, and connect to stepgen.4.velocity-cmd instead of the spindle speed.
Time to create page: 0.134 seconds
