Can't threads be executed in the remapping script?
- chen1234
4 years 10 months ago #229284
by chen1234
Can't threads be executed in the remapping script? was created by chen1234
I created a thread in the remapping code, but it cannot execute the loop in the thread.
I remapped a code to receive an external io signal. I need to read this signal in a loop for judgment, so I created a thread and let this loop execute in the thread. But when I tested this code, I found that it could not execute the function in this thread. I don't know why. My thread was created successfully. Hope someone can give me advice.
#!/usr/bin/env python3
import struct
import sys
import os
from interpreter import *
import hal
import linuxcnc
import _thread
def Z_jogs(self,a):
print('a = ',a)
b=a
print('b=',b)
while True :
x = hal.get_value('lcec.0.5.RXPDO-5') #read EtherCAT io
print('x_in5 =',x)
if x == 1:
print("in5 = ",x)
self.execute("G0 Z %d"%b) #Control Z axis movement
b += a
elif x == 0:
print("in5 = ",x)
if hal.get_value('lcec.0.5.TXPDO-2') == 1:
break
# read EtherCAT io
def m203(self,**words):
yield INTERP_EXECUTE_FINISH
if self.task:
self.Z_jogs = Z_jogs()
a = (words['s'])
print("a=",a)
try:
_thread.start_new_thread(Z_jogs,(a,))
print('qw')
except:
print('erro')
4 years 10 months ago #229288
Replied by andypugh on topic Can't threads be executed in the remapping script?
I haven't tried this, but I really wouldn't expect it to work.
Why do you want to start a thread? Can you explain what you are trying to do?
- chen1234
4 years 10 months ago #229535
by chen1234
Replied by chen1234 on topic Can't threads be executed in the remapping script?
Thank you for your reply,
my job is like this: I need to control the Z-axis movement by receiving the feed signal of the scanning head.
It works as follows: When the device is in the hole-making state during operation, it will send a high-level signal to my EtherCAT board. When I receive this signal, I need to control the Z-axis movement for a specified distance. This high-level signal It is not continuous, so I need a thread to let it execute the read signal in a loop. But the problem I currently encounter is that the thread is successfully created and the function is not executed. Is the remapping code not supporting threads? Or is there another way?
- Thank you received: 2181
4 years 10 months ago #229536
Replied by cmorley on topic Can't threads be executed in the remapping script?
M66?
4 years 10 months ago #229652
You can probably do this with a custom HAL component and the external offsets feature.
linuxcnc.org/docs/2.8/html/motion/external-offsets.html
Time to create page: 0.860 seconds
