movement pauses during the execution of an MCode
- mich94
4 years 1 month ago #251486
by mich94
it works fine but my thesis work is to improve the printing: by making so i made a bunch of functions that calculate the speed of the estruder in all the planned path, then using another algorithm i calculate the best pressure for an uniform extrusion.
I then need to change the pressure (in the G-code) in the points where the speed change over a certain threshold (in the change of direction).
Here comes the problem because when i use the "M3 Snnn" that change the voltage output, that change the pressure of extrusion, the robot stops and this generate an accumulation on the printing path.
i included all the attachments i got for a complete view
thank you for all the help
Replied by mich94 on topic movement pauses during the execution of an MCode
correctI think you have a lot of things very confused
also correct,Do you have a machine configuration that "mostly" works for you except for the pauses in motion when you try to change the extruder feed using M3Snnn?
- Thank you received: 2177
4 years 1 month ago - 4 years 1 month ago #251501
Replied by Aciera on topic movement pauses during the execution of an MCode
You could try to manipulate the analog spindle output of the 7i76 with the float value in
"motion.analog-out-00".
So either try to feed your desired "speed" directly into this:
net spindle-output => hm2_7i80.0.7i76.0.0.spinout
Or use the "halui.spindle.0.override" pins
linuxcnc.org/docs/html/man/man1/halui.1.html
Note that, if I remember correctly, the 7I76 will only output the analog signal if hm2_7i80.0.7i76.0.0.spinena is true.
edit: personally I would try the override first
Last edit: 4 years 1 month ago by Aciera.
The following user(s) said Thank You: mich94
- mich94
4 years 1 month ago #252329
by mich94
thank you for the answer!
sorry for my late reply
for what i read i have understood that the override can provide an increment or decrement of actual pin value (am i right?), what i need is to change the value multiple time with some pre-calculated numbers,
for this reason i think i could not follow your personal suggestion
by the way i think the first way you exposed could be the right one! :side:
i'm now studying the HAL file in order to "manipulate the analog spindle output with the float value in motion.analog-out-00" as you said
i already have the command for "net spindle-output => hm2_7i80.0.7i76.0.0.spinout" in the HAL so i guess i need to change the link for "spindle-output" that now is on the PID to the analog.motion
(now is "net spindle-output <= pid.s.output")
- mich94
4 years 1 month ago #252343
by mich94
we got it guys!!
thanks for all your help and time!
the Gcode now starts with an M3 M67 E0 Qxxx so the spindle is activated and the speed is modified by the pin 00, when i need to change the pressure i just M67 E0 Qxxx and it changes without stopping the motion
i just changed 1 line in the .hal file:
it was : net spindle-output <= pid.s.output
it became : net spindle-output <= motion.analog-out-00
(replies will follow if something don't go as planned)
Time to create page: 0.158 seconds
