Parametric G-Code; take axis name/ID from a variable?
4 years 4 weeks ago #253413 by swarren
I am writing a script to automate touch-off against a probe bar. I have written the same script 3 times; once each for the X, Y, and Z axes. The body of the script is identical in all 3 cases except for the axis name in the G38/G01 commands. Is there any way to use a variable for the axis name, so that I can either (a) use a sub-routine for the body of the script, or (b) make the scripts 100% identical so that it's easier to keep them in sync using "diff" or similar?
My current Z-axis script:  github.com/fortcollinscreatorhub/cnc/blo...cnc/nc_files/100.ngc
My current X-axis script:  github.com/fortcollinscreatorhub/cnc/blo...cnc/nc_files/103.ngc
My current Y-axis script:  github.com/fortcollinscreatorhub/cnc/blo...cnc/nc_files/104.ngc
Some ideas that have been suggested:
a) Include all 3 of X, Y, Z axes in each G38/G01 command, and have separate probe_x/y/z_dir variables (with value -1 or 1 for the desired axis, and 0 for the other 2 axes, which will zero out the movement in unwanted directions). This will work, but will make the script a bit harder to read and understand.
b) Maybe "G10 L2 P0 R90" can be used to rotate between X/Y axes, but I'm not sure, and it won't work for Z.
Ideally, I'd love to do this: "G38.3 #<axis_name>[#<probe_dir> * #<probe_max_distance>] F[#<fast_probe_rate>]". However, variables can apparently only contain numbers, not strings/text:-(
Thanks for any ideas!
4 years 3 weeks ago - 4 years 3 weeks ago #253471 by andypugh
O100 IF [#<axis> EQ 0] G38.2 X100 F20 O100 ELSEIF [#<axis> EQ 1] G38.2 Y100 F20 O100 ELSEIF [#<axis> EQ 2] G38.2 Z100 F20 ... O100 ELSEIF [#<axis> EQ 9] G38.2 W100 F20 O100 ELSE (ABORT, Something went terribly wrong) O100 ENDIF
linuxcnc.org/docs/stable/html/gcode/o-co...ml#ocode:conditional
Last edit: 4 years 3 weeks ago by andypugh.
4 years 3 weeks ago #253481 by swarren
That would work, but I'd essentially be replicating the program many times within the if statement. I was hoping for one statement that'd cover all the axes.
I'm thinking of just writing a custom M code in Python, since that allows much more flexible use of variables...
4 years 3 weeks ago #253491 by swarren
OK, so I've started to work out how to do this in a Python remap. A couple of questions:
1.  linuxcnc.org/docs/stable/html/remap/rema...ming-embedded-python says:
  • Code following a yield may not recursively call the interpreter, like with self.execute("<mdi command>"). This is an architectural restriction of the interpreter and is not fixable without a major redesign.
However, in practice my code is calling self.execute() after yielding, and works fine. Are the docs simply out-of-date, or are there cases where I'll see this randomly break if I'm unlucky?
2. How stable is this Python remap feature? Clearly if I write my code in G-Code, it's quite likely to keep working whenever I upgrade  LinuxCNC. However, since Python remaps seem like a less commonly used and documented feature, I worry whether using it may cause headaches for some future maintainer of this machine, e.g. if I'm no longer involved in a few years and someone upgrades LinuxCNC, then everything breaks and they have a hard time fixing it if they aren't a programmer.
For the record, here's the very bare skeleton that I've been using to test the feature:
configs/sim/axis/axis.ini:
[PYTHON] PATH_PREPEND= python TOPLEVEL= python/toplevel.py LOG_LEVEL = 8 [RS274NGC] REMAP= M400 py=fcch_probing
python/toplevel.py:
import remap
python/remap.py:
from interpreter import * def fcch_probing(self, **words):     try:         self.execute("G91")         self.execute("G38.3 X1 F10")         yield INTERP_EXECUTE_FINISH         self.execute("G0 X-0.25")         self.execute("G38.3 X0.5 F2.5")         yield INTERP_EXECUTE_FINISH         self.execute("G0 X-0.5")     except InterpreterException as e:         self.set_errormsg(e.error_message)         return INTERP_ERROR     return INTERP_OK
4 years 3 weeks ago #253507 by andypugh
Maybe only the probe moves, it depends on what the rest of the code does. You can pull out the correct probe result bu a computed parameter, for example.
4 years 3 weeks ago #253509 by andypugh
A remap should be as stable as Python, which isn't saying much. I would definitely target Python 3.
Time to create page: 0.290 seconds
