Parametric G-Code; take axis name/ID from a variable?
4 years 3 weeks ago #253592 by swarren
For anyone finding this thread later by Google, an update on the Python approach:
I've found an example of the problems that the documentation describe, where you can't issue and wait for multiple batches of G-Code commands within a Python remap. If I execute the remapped G-Code from the MDI, the code I wrote above works. If I execute the remapped code from 100.ngc which I trigger from an Axis UI button, then I get an error:
    self.execute("G38.3 X1 F10")     yield INTERP_EXECUTE_FINISH     print(5070, self.params[5070])     # The execute() below works, if M400 executed from the MDI UI     # The execute() below raises the following, if M400 executed from 100.ngc, triggered from an Axis UI button:     #    emc/task/emctask.cc 69: interp_error: exception during generator call: Traceback (most recent call last):     self.execute("G0 X-0.25")
So, I guess I'll do this in plain old G-Code.
Time to create page: 0.258 seconds
