M3 Does Not Behave as Expected
- reynolds087
- Thank you received: 4
18 Feb 2023 18:51 #264767
by reynolds087
M3 Does Not Behave as Expected was created by reynolds087
I am curious whether anyone else can confirm this behavior, because it caused me some significant headache while I was troubleshooting my spindle. This is my first experience with LinuxCNC. Originally I was using GRBL, which behaves in the following way. When "M3" is asserted, the spindle is enabled. If an S code is asserted on the next line, the spindle will output the corresponding speed.
Example:
M3
S1000 (Spindle will rotate at 1000 rpm)
This is not the case in my experience with LinuxCNC. The only way I can get the spindle to initialize is to issue the speed command on the same line as the "M3" command. After that first command, you can then assert individual spindle speed commands, but if the speed is omitted on the first line, you will not get any output from the spindle. So only this works:
M3 S0
S1000
Was this by intent, and if so, does anyone have an explanation for why?
Example:
M3
M3 S0
S1000
- Thank you received: 7487
18 Feb 2023 21:18 #264773
Replied by tommylight on topic M3 Does Not Behave as Expected
Not using mills so i might be off, but i am sure that LinuxCNC will enable the spindle without the S value only if there is nothing related to PWM or PDM and direction in the hal/ini files.
Otherwise it does require the S value.
Later versions of LinuxCNC may require also an $n as there is support for multiple spindles implemented now, so
M3 S3000 $1
should run the second spindle at 3000 RPM.
Please do double check this, as i said, i do not use mills, yet!
M3 S3000 $1
- Thank you received: 5329
18 Feb 2023 21:31 #264774
Replied by PCW on topic M3 Does Not Behave as Expected
I don't see this issue.
If I start LinuxCNC and run this gcode:
m3
s200
g4 p5
s1000
g4 p5
m2
The spindle is enabled and runs at 200 RPM for 5 seconds and
then runs at 1000 RPM for 5 seconds, then is turned off by M2
m3
s200
g4 p5
s1000
g4 p5
m2
- reynolds087
19 Feb 2023 05:16 #264793
by reynolds087
Replied by reynolds087 on topic M3 Does Not Behave as Expected
PCW,
You helped me with my offset and scaling recently. Do you think there is anything in that code that would cause this behavior?
- Thank you received: 2181
19 Feb 2023 06:16 #264794
Replied by cmorley on topic M3 Does Not Behave as Expected
What version of linuxcnc? The behavior was changed in 2.9 I believe.I am curious whether anyone else can confirm this behavior, because it caused me some significant headache while I was troubleshooting my spindle. This is my first experience with LinuxCNC. Originally I was using GRBL, which behaves in the following way. When "M3" is asserted, the spindle is enabled. If an S code is asserted on the next line, the spindle will output the corresponding speed.
Example:
M3
M3 S0
S1000
19 Feb 2023 19:42 #264825
Replied by andypugh on topic M3 Does Not Behave as Expected
Did you say that you have modified LinxCNC to enable M3 remapping, and are running a remap routine? Or was that someone else?
19 Feb 2023 22:03 #264831
ahh, I was testing with 2.9 so that may be the issue.
Time to create page: 0.242 seconds
