- Thank you received: 10
Do you have an ARC OK input from the plasma cutter?..... right after the torch has descended from pierce height to cutting height, so that i can use M3 to open the arc and open a valve for piercing gas, and after pierce use M7 to open a valve for cutting gas?
It would be good if an oxy user could map out the required steps to probe for material, fire the oxy torch and do whatever to the gasses to give a bit of a framework for Phil to work off.I want to retrofit an oxygas machine with linuxcnc so these are some of the troubles that i find. I have no problem in adding a float sensor to my oxy torch.
thank you!
