I am pretty sure i wrote at least twice the procedure for working with oxy on this forum, on the phone so google-foo is weak now.
Again, these are what i gathered so far, please do check everything.
Quick recap:
-Probing possible only with inductive sensor, the round thing around the torch.
-flame can not be off, so only cutting gas controling a valve
-oxy must use preheating, for long periods of time, othevise the material warps a lot
-preheating is done from 20-50mm high, cutting gas is off
-cutting is done from 5-10mm high
-preheating timer might need 30 minutes for thick plates
-piercing is done with cutting gas active
-cutting is usually slow, depends on thicknes and torch type/nozzle
-rarely needs hight adjustment during cut, thick plates and preheating minimise that, but might need on longer cuts
-using two normal inductive sensors can be used for height adjustments, but might melt on small cuts due to heat
-usable for cutting 20-160mm thick plates, even more with special torches
-new cutting torch with 3 inlets for cutting up to 70mm is 170 euro here, gas is way to expencive, 4 months ago oxygen tank fill was 120 Euro!
-probably forgot something...
