Possible bug?
- 2e0poz
I generated some code using DXFtoGcode and also in GCNCCAM (it does not matter which same result in the end), loaded it and run the the code and worked fine. generate more code for new objects and loaded it and EMC complains about gouging in concave corners. This happens no matter what generator i use and works again if i create a new machine profile (stepconf) then load the code and its fine until i load the next file. The code is good and all i can think of is that the tool compensation is being held in the config of EMC somewhere? The tool table only has one tool in it with the correct diameter of cutter (4.5mm). i've attached the code if you want to see and would appreciate any feedback please it's doing my head in.
Attachment 22mmbearing.ngc not found
- 2e0poz
The code is just a guide and it does not matter which drawing i use created from any cam software (even mastercam).
- BigJohnT
- Thank you received: 994
- 2e0poz
I can't view the G-code other than as text here, but your first G2 move looks very tight for a 4.5mm tool.
- BigJohnT
- 2e0poz
Paul
T1 is set to 4.5mm in the tool table so still not sure the code can be at fault here.
But it is wrong.
Your first G2 move demands a 3.182mm diameter hole with diameter compensation active and a 4.5mm dia cutter.
(G2 is clockwise, G42 is cutter to the right)
That is simply not possible, and EMC2 points that out to you.
You say that the code runs fine in Mach, but I rather suspect that after that first move there isn't a 3.182mm diameter hole, there will be either a 4.5mm hole, or possibly a 5.818mm dia hole. The difference is not that Mach is superior to EMC2, but that it doesn't have gouging detection.
If you are trying to leave a 3.182mm dia "peg" then you need to either make the first cut a G3, or use G41 compensation.
- BigJohnT
Just to note the drawing does no appear when i load the code just a small dit in the middle of the table (roughly where start position should be). Thanks for the feedback so far
Paul
Only that portion of g code that is runnable (no errors in coding) will display on the back plot. As soon as the error is discovered then the preview stops loading at that point and does not try and load any more. As Andy pointed out your code may run on other systems without gouge protection but you will not like the part when it is done.
- 2e0poz
i think i understand now and can see i will be a while in getting to grips. As for Mach being more superior that i feel not, i do like the sound of the protection i am actually getting from EMC. I will have a play with the tools today and would like to thank you for clearing this up. This is what makes EMC a great community and not just a tool.
Many thanks
Paul
