- Thank you received: 4
Thank you.
But if you just want to compare two numbers to see if they differ by less than a certain amount:
Code:O100 IF [ ABS[#100 - #101] LT 0.01] <do stuff> O100 ENDIF https://linuxcnc.org/docs/html/gcode/overview.html#gcode:functions https://linuxcnc.org/docs/stable/html/gcode/o-code.html#ocode:conditional
Thank you! It's HELPED!!The trick here is probably
Code:O100 while [#<_task> EQ 1.0 AND #<_deltaabs> GT 0.007]
