Setting home position using gcode
- garthnoakes
- Thank you received: 9
14 Jul 2024 07:06 #305133
by garthnoakes
Setting home position using gcode was created by garthnoakes
How do I set the current position to x=0,y=0,u=0,v=0 (hot wire machine....) using gcode ? At this stage, I don't want to move the location, I just want to emulate setting home via the Axis home buttons
- Thank you received: 2177
14 Jul 2024 07:27 - 14 Jul 2024 07:28 #305137
Replied by Aciera on topic Setting home position using gcode
Last edit: 14 Jul 2024 07:28 by Aciera.
- garthnoakes
15 Jul 2024 10:13 #305240
by garthnoakes
Replied by garthnoakes on topic Setting home position using gcode
That works - but only if the axes are already homed. I want to get rid of the need to home each axis separately in Axis when I start LinuxCNC. I will use GladeVCP to create a button to run the G10
So is there a way to emulate manually homing each axis using Axis?
- Thank you received: 4662
15 Jul 2024 10:28 #305243
Replied by andypugh on topic Setting home position using gcode
You can set the home search velocity to zero in the INI file for any joints that you want to home where they are. But this means that you have no soft limits.
It's much better to actually home the axes, if you can.
- garthnoakes
15 Jul 2024 17:44 #305289
by garthnoakes
I'm happy with homing the axes, I just want to add a button using gladevcp that will set all four once I have jogged the wire to where I want home to be. Not at all important, just being a bit pernickety
- Thank you received: 4155
15 Jul 2024 22:58 - 15 Jul 2024 22:58 #305313
Replied by rodw on topic Setting home position using gcode
Try halui.home-all bit in pin for requesting home-all (only available when a valid homing sequence is specified)
Last edit: 15 Jul 2024 22:58 by rodw.
Time to create page: 0.087 seconds
