How to Control a PWM Gripper
2 years 2 weeks ago #311986 by Project_Hopeless
I have my hobby robot gripper working and an Axis GUI slider to manually control/test it.  So now I need a hook to control the gripper from an eventual gcode program.
I'm thinking of having 3 states, Open, Close, Variable.  I'll need to output a float value, so is this best suited for G, M, O, or other code?
Secondly are "aliases" possible in gcode?  For example "Gripper Open"  or "M65 Open" something relatively simple.
######## rcPWM Gripper Control setp hm2_[MESA](BOARD).0.rcpwmgen.rate 50 setp hm2_[MESA](BOARD).0.rcpwmgen.00.width 1 setp hm2_[MESA](BOARD).0.rcpwmgen.00.offset 1.39 setp hm2_[MESA](BOARD).0.rcpwmgen.00.scale 180 net PWMcmd  pyvcp.servo-f  hm2_[MESA](BOARD).0.rcpwmgen.00.width        #float
2 years 2 weeks ago #311991 by Aciera
Replied by Aciera on topic How to Control a PWM Gripper
You could use the 'motion.analog-out' pins (M68):
linuxcnc.org/docs/html/gcode/m-code.html#mcode:m68
If you wanted you could define your own M-code or Subroutine that sets a particular analog output pin so you would not have to enter the E-word all the time.
We cannot pass strings in gcode and the only way to use something like that would be a subroutine (eg o<yoursubroutine>call)
2 years 2 weeks ago #311997 by Project_Hopeless
I'm thinking about readability, so is this possible with subroutines...
Open CALL
Close CALL
Open 50 CALL (representing 50% full scale)
2 years 2 weeks ago #312037 by Aciera
No that is not possible, subroutine calls need to use the 'O' Word (O <your_subroutine> CALL)
Note: lowercase lettering is also fine like in my last post. Subroutines can also accept parameter values (O <your_subroutine> CALL [123] [456] ...)
Remapped Mcodes can also pass P and Q words: (M456 P1 Q2)
1 year 10 months ago #316995 by robocidalmaniac
Has anyone been able to use M codes to operate a Robotic Arm gripper yet? I have a post for a Scorbot-ER-3 and Linuxcnc 2.9.1 which uses a gui and mouse to open and close the gripper, but need to make a M code for this function. Please help
1 year 7 months ago #323536 by robocidalmaniac
Please a few questions.
I have a Scorbot-ER-3 (with original control box) working using LinuxCNC, But cannot activate the gripper using G-Code commands or the Logitech dual action F310 controller pendant. When Andy designed this for LinuxCNC in 2020 the only way to open or close the grippers is through a GUI pop-up box and the mouse.
Thank you for your time.
Time to create page: 0.357 seconds
