dumb question about depth of cut
- yugami
20 Nov 2010 23:33 #5477
by yugami
dumb question about depth of cut was created by yugami
I'm finishing getting the MaxNC T2 lathe repaired/configured and have both axis working (spindle to be finished when I get some parts)
If I where to program a simple profile that has a depth greater than I can cut in one pass does EMC do multiple passes?
You can tell I don't know anything about CNC
- BigJohnT
- Thank you received: 994
20 Nov 2010 23:57 #5479
by BigJohnT
Replied by BigJohnT on topic Re:dumb question about depth of cut
That is something you do in the CAM program or if you write your g code by hand you have to do it. I have some lathe subroutines in the subroutine section here that are a big help (to me) with one off's on my lathe.
- yugami
21 Nov 2010 02:26 #5480
by yugami
Replied by yugami on topic Re:dumb question about depth of cut
Thanks john, I'll do a bit more reading. I figured as much but couldn't be sure.
I'm trying to use the Inkscape plugin that is referenced in the CAM forum here, I'll ask there how they handle that sort of thing.
Time to create page: 0.071 seconds
