My Speeds dont work for my M codes.
- Rune_cnc
26 Dec 2024 22:27 #317437
by Rune_cnc
My Speeds dont work for my M codes. was created by Rune_cnc
Hi all
I'm having issues with spindel setup.
The spindel not getting the 0-10v needed to run.
I can get the 7i76U (new) hooked up to old 6i25, to turn the spindel by
enable HM2_5i25.0.7i76.0.0.spinena-invert (or spinena)
Upping the xxx.spinout.minlim
But im unable to edit or use xxx.spinout and M codes dont work to start up spindel.
I added firmware "5i25_7i76x2r.bit" to the 6i25 to get the card to read.
And have external 10v supply for the spindel. Took the negative from driver back to the 24v ground.
Seem to have some noise, not sure who it should be hooked up.
It might be the firmware or something Im missing in the hal and ini.
I really dont know.
I'm unable to edit the xxx.spinout in Halshow to make the spindel spin. Like I think maybe it should be.
Any tips, all this CNC is new for me.
Added hal and ini if anyone would want to look
I really dont know.
- Thank you received: 5320
26 Dec 2024 22:40 #317438
Replied by PCW on topic My Speeds dont work for my M codes.
Your hal/ini files did not get attached.
The following user(s) said Thank You: Rune_cnc
- Rune_cnc
26 Dec 2024 23:38 #317442
by Rune_cnc
Replied by Rune_cnc on topic My Speeds dont work for my M codes.
26 Dec 2024 23:47 #317443
The hal/ini files look basically OK
If you start LinuxCNC, enable the spindle, and set a say 1/2 way up spindle speed
Then running this command in a terminal wndow should provide debug information to post here:
halcmd show all | grep spindle
- Rune_cnc
05 Jan 2025 16:44 #318163
by Rune_cnc
Thanks for you input.
You where correct. Im almost embaressed to tell this.
I turned off the machine and had xmas/new year.
Came back at it was working.
Just needed a good reboot.
But I have a follow up question.
I cant figure out why it gets in to a frenzy when I press stopp.
Must be the driver.
But is there any way to stop this.
in linuxcnc.
youtube.com/shorts/21x_UrOSCuE?si=IMhtfS7cgKt6L2Jk
What is deadband for
Must be the driver.
in linuxcnc.
