gcode sample file?
1 year 9 months ago #317968 by CaspianCmonster
Hi all, I am trying to troubleshooting my router set up on qtdragon_hd  with manual tool change with a tool length sensor. It will run the tool length procedure just fine (without a multi-tool file loaded) and will run a single tool gcode no problem but starts yelling at me when I try to run anything with a M6 command. The issues are probably not with the gcode I am using but just to be sure can someone please send me a simple example of a part with three tool changes? I am using mm.
many thanks
Luke
1 year 9 months ago #318074 by tommylight
Replied by tommylight on topic gcode sample file?
% G0 X0 Y0 F200 #set this to whatever is OK for your machine M6 T1 G1 X50 Y50 M6 T2 G1 X100 Y100 M6 T3 G1 X0 Y0 %
Time to create page: 0.160 seconds
