rotation plane around y axis in g18
- papagno-source
- Thank you received: 13
16 Jan 2025 00:00 #319062
by papagno-source
rotation plane around y axis in g18 was created by papagno-source
Hi.
In linuxcnc we have g10 l2 px rx and rotation plane xy around z on px origin selected.
For plane g18 not have implementation for linuxcnc ?
- Thank you received: 4648
17 Jan 2025 18:51 #319205
Replied by andypugh on topic rotation plane around y axis in g18
No, rotation about Z is a special case.
Rotation of the other planes (including uvw) might be nice, though there doesn't seem to have been many requests for it.
- papagno-source
18 Jan 2025 15:42 #319293
by papagno-source
Replied by papagno-source on topic rotation plane around y axis in g18
I think that for a cnc, rotations in the G17-G19-G20 planes are fundamental. There are many machines that have a double spindle, one installed vertically and the other horizontally. In these cases it is necessary to change the plane and the rotation of the plane, allows to greatly facilitate the work of programming the piece.
- Thank you received: 2165
18 Jan 2025 17:39 #319297
Replied by Aciera on topic rotation plane around y axis in g18
The usual approach is to create a configuration for vertical and another for horizontal operation but
one can easily create a kinematic that allows for switching between vertical and horizontal spindle orientation even in Gcode.
- papagno-source
19 Jan 2025 17:15 #319386
by papagno-source
Thanks for reply.
Please can write a example for orientation plane in Gcode.
Much thanks.
Much thanks.
19 Jan 2025 17:52 #319388
For a basic example have a look at the 'configs/sim/axis/vismach/millturn' for a similar use case.
The kinematic file used is this one:
github.com/LinuxCNC/linuxcnc/blob/master...onents/millturn.comp
For a simple vertical/horizontal kinematic you would only need to change this:
to
case 0:
pos->tran.x = j[0];
pos->tran.y = j[1];
pos->tran.z = j[2];
pos->a = j[3];
break;
case 1:
pos->tran.x = j[2];
pos->tran.y = -j[1];
pos->tran.z = j[0];
pos->a = j[3];
break;
// unused coordinates:
pos->b = 0;
pos->c = 0;
pos->u = 0;
pos->v = 0;
pos->w = 0; case 0:
pos->tran.x = j[0];
pos->tran.y = j[1];
pos->tran.z = j[2];
break;
case 1:
pos->tran.x = -j[0];
pos->tran.y = j[2];
pos->tran.z = j[1];
break;
pos->a = 0;
pos->b = 0;
pos->c = 0;
pos->u = 0;
pos->v = 0;
pos->w = 0;Please Log in or Create an account to join the conversation.
- papagno-source
19 Jan 2025 22:21 #319415
by papagno-source
I am very grateful for the support you give us.
- papagno-source
19 Jan 2025 22:46 #319417
by papagno-source
I have add millturn.com.
When compile with make , have :
hal/components/millturn.comp: In function ‘millturn_setup’:
hal/components/millturn.comp:71:9: warning: implicit declaration of function ‘hal_set_unready’; did you mean ‘hal_port_read’? [-Wimplicit-function-declaration]
if (hal_set_unready(comp_id)) goto error;
hal_port_read
Linking ../rtlib/millturn.so
I use debian 10 with linuxcnc 2.9.pre0.
i have add milturn.comp at core_sim.hal in axis sim , have error :
Note: Using LXRT realtime
millturn: dlopen: /usr/lib/libint/rtlib/millturn.so: undefined symbol: hal_set_unready
how can resolve this ?
hal_port_read
19 Jan 2025 23:02 #319418
I think you would have to update to 2.9.3.
- papagno-source
22 Jan 2025 18:17 #319652
by papagno-source
Hi.
For testing , is can modification trivkins kinematics for it , or is complicated.
