G41 G42 Problem
- Chris54636
17 Feb 2025 14:51 #321838
by Chris54636
G41 G42 Problem was created by Chris54636
Hi, normaly i only read in this forum, but now i have to ask about the G41/G42 funktion.
There are many discussions about whether G41/G42 calculates the approach route correctly or not.
I don't want to pursue these discussions any further, but am more interested in a solution.
It is possible that LinuxCNC can approach correctly with a sufficiently large radius. Unfortunately, I have not yet figured out how to work around the problem if I do not have enough space. I would like to mill a Ø5 hole with an Ø4 end mill.
How is it possible to mill the hole with linuxcnc and G41/G42 without already activating the G41/G42 above the part?
All CAM systems known to me only support the normal G41/G42 but not the Linuxcnc version. I have already tried to convert the coordinates in PP, but so far without success. Does anyone know a solution for this?
As I am not the only one with this problem, it would be advantageous if linuxcnc supported both versions. Maybe a G41.2/G42.2 could be the solution.
Best Chris
Best Chris
- cakeslob
- Thank you received: 280
19 Feb 2025 03:30 #321959
by cakeslob
Replied by cakeslob on topic G41 G42 Problem
its in imperial though
5mm hole, 4mm endmill .001" or something in tooltable diameter
O0001 (5mm_w)
(MCX FILE - T)
(PROGRAM - 5mm_w.NC)
(DATE - FEB-18-2025)
(TIME - 5:57 PM)
(T3 - 1/8 FLAT ENDMILL - H3 - D3 - D0.1575")
(1/8 CIRCLEMILL_FINISH_WEAR)
N3 T3 ( 1/8 FLAT ENDMILL)
M06
G00 G17 G90 G54 X0. Y0. S9168 M03
G43 H3 Z.25 M08
Z.1
G01 Z-.5 F10.
G41 D3 X.0098 Y.0098 F5.
G03 X0. Y.0197 I-.0098 J0.
Y-.0197 I0. J-.0197
Y.0197 I0. J.0197
Y-.0197 I0. J-.0197
Y.0197 I0. J.0197
Y-.0197 I0. J-.0197
Y.0197 I0. J.0197
X-.0098 Y.0098 I0. J-.0099
G01 G40 X0. Y0.
G00 Z.25
M30
The following user(s) said Thank You: Chris54636
- Chris54636
19 Feb 2025 12:40 #321979
by Chris54636
Replied by Chris54636 on topic G41 G42 Problem
Hmmm, you meen i can change the diameter in the tool table from 4mm to 1mm.
If i also reduce the diameter in the program by 3mm, it is possible to use G41.
Yes, this is a possibility, but not a nice one, where mistakes can easily happen.
I understand that many people want to keep the current function of G41, but what's wrong with a 2nd function that works like all other controllers and doesn't require any tricks?
Best Chris
Best Chris
- Thank you received: 2165
19 Feb 2025 15:44 #321994
If you can provide the code changes needed for this in a pull request on github then I'm sure there would be a fair bit of interest. If you are hoping for others to implement it then that is likely a different story.
Replied by Aciera on topic G41 G42 Problem
