Probe getting triggered for non probic moves
- Nathan40
20 Feb 2025 15:31 #322078
by Nathan40
Probe getting triggered for non probic moves was created by Nathan40
Probe getting triggered in non probic moves. As a result the gcode programs are subsequently failing in linuxcnc 2.9.2 version. This never happened in previous versions. Please help!
- Thank you received: 4149
21 Feb 2025 01:07 #322144
Replied by rodw on topic Probe getting triggered for non probic moves
Most likely a loose connection or bounce. maybe use debounce?
- Nathan40
21 Feb 2025 01:38 - 21 Feb 2025 09:23 #322150
by Nathan40
Replied by Nathan40 on topic Probe getting triggered for non probic moves
A. Is there a way in HAL that only allows spindle on or probe on ? Please share HAL code if possible.
B.Used debounce value 10. Should i lower or increase this value? Hope it doesn’t affect the probe performance. Please share any inputs / experience for the same. Please can you share changes in custum.hal files.
Last edit: 21 Feb 2025 09:23 by Nathan40.
Time to create page: 0.378 seconds
