M66 keeps waiting
1 year 2 months ago #333125 by Firehunter
Replied by Firehunter on topic M66 keeps waiting
Thanks for the replies. I guess updating Linux and LinuxCNC is the only option left. The machine is at an other location, I will try installing the updates when I'm there again.
I made some changes to the gmoccapy interface, added some custom buttons using the Glade editor if I remember correctly. Will these modifications be overwritten when I do the updates?
1 year 2 months ago #333156 by rodw
Replied by rodw on topic M66 keeps waiting
Te linuxcnc folder is preserved on an upgrade but keep a copy off the pc.
What version of linuxcnc are you using? Versions before 2.8 might need some more work.
I have found its best to build a rough config with stepconf or pncconf, then cut and paste your ini file data into the generated ini file.It only takes an hour or so that way.
1 year 2 months ago #333174 by andypugh
Replied by andypugh on topic M66 keeps waiting
Note that I don't actually expect that to fix this issue.
Can you attach your HAL files(s)?
1 year 2 months ago #333189 by PCW
Replied by PCW on topic M66 keeps waiting
The sample code works (standalone) for me,
That is just by manipulating/watching the pins in halshow:
1 year 2 months ago #333274 by Firehunter
Did you run it as G-code? Which version LinuxCNC and OS are you using?
1 year 2 months ago #333276 by PCW
Yes, I just copy/pasted the G code sample into a file.
It worked with master and 2.9.4 (I can't easily try 2.8 because of the Python 2-3 change)
I don't think the OS matters but this is Mint 20.2 with a recent kernel (6.15)
Time to create page: 0.287 seconds
