- Thank you received: 4
Helical milling with a diagonal repeat ?
- cncnoel
12 years 3 months ago - 12 years 3 months ago #48746
by cncnoel
Replied by cncnoel on topic Helical milling with a diagonal repeat ?
Glad to hear you're making good progress markjacks
As you've probably noticed, the <tunepin> subroutine uses the values, whereas the <hole> subroutine uses named GLOBAL variables.
A named global variable has an underscore before it's name as in #<_safeZ>, and once defined (#<_safeZ> = 5.0) can be used in any subroutine.
A named LOCAL variable such as #<Feed> (no underscore) can’t be accessed outside of its subroutine - that way you can
use the same parameter name with a different value in different subroutines.
I like to use lots of white space in my G-code too, because it makes it easier for me to read (6 or so months) later on. Because the interpreter ignores
white space, it makes good sense for us humans to take advantage of this.
is a lot easier to read than
I have my text editor set to show a right margin at 80 characters & tabs set to 4 spaces
& lately I have set it to replace tabs with spaces, so when using a different editor, things still align OK.
Playing with white space a bit, adding the P parameter, plus sexy entry an exit maneuvers (improves work finish) your code might look like
I prefer my comments off to the right so the flow of the code isn't interrupted.
Here is an over-commented example, using a line-feed to separate the sections
Hope this helps.
Regards to all
Noel
G91
G1 F500 Y1.1
(HELIX-BORE TO DEPTH)
G3 Y-2.2 J-1.1 Z-0.1
Y 2.2 J 1.1 Z-0.1
Y-2.2 J-1.1 Z-0.1
Y 2.2 J 1.1 Z-0.1
Y-2.2 J-1.1 Z-0.1
Y 2.2 J 1.1 Z-0.1
Y-2.2 J-1.1 Z-0.1
Y 2.2 J 1.1 Z-0.1
(STAY AT BOTTOM)
G1 F500 Z-0.1
Y-2.2 J-1.1
Y 2.2 J 1.1
(RETURN TO POSITION)
G1 F500 Y-1.1
F1000 Z 1
G90
G91
G1 F500 Y1.1
G3 f500 Y-2.2 J-1.1 Z-0.1
G3 f500 Y2.2 J1.1 Z-0.1
(STAY AT BOTTOM)
G1 f500 Z-0.1
G3 f500 Y-2.2J-1.1
G3 f500 Y2.2J1.1
G1 f500 Y-1.1
G1 f1000 Z1
G90
(Hole Centre)
G90
G00 Z10 F500
X100 Y100
Z0.1
(Swoop in)
G91
G2 Y-1.1 J-0.55 Z-0.1
(Helix bore to depth)
J1.1 Z-0.8 P8.0
J1.1
(Helix out)
J1.05 Z0.9
(Hole Centre)
G90
G00 Z10
X100 Y100
M30
(drill_code)
G90 (absolute position)
G00 Z10 F500 (Safe height)
X100 Y100 (Hole Centre)
Z0.1 (pre-swoop height)
G91 (increment position)
G2 Y-1.1 J-0.55 Z-0.1 (Swoop in)
J 1.1 Z-0.8 P8.0 (Helix bore to depth)
J 1.1 (level at depth)
J 1.05 Z0.9 (Helix out)
G00 Z10 (Safe height)
M30 (sweep the chips up)
Regards to all
Noel
Last edit: 12 years 3 months ago by cncnoel.
Time to create page: 1.000 seconds
