- Thank you received: 595
Error combining cutter compensation (G41/42) with work offset (G55)
- RotarySMP
- Topic Author
8 months 2 weeks ago #343047
by RotarySMP
Error combining cutter compensation (G41/42) with work offset (G55) was created by RotarySMP
Hi all,
At 19:55 in this video...
I was making a set of lathe tool height adjusters, and used a loop with G55 to repeat my tool paths along a piece of stock. This worked great for engraving and drilling such as this code...
o100 Sub
G0 X0 Y0
G0 Z5
G01 Z-2 F100
G01 Y-14.5 F1000
G01 X10.5 Y-20
G01 X21
G01 X30 Y-14.5
G01 Y0
G01 X0
G0 Z50
o100 endsub
#50 = 0
G17 G21 G54 G90
; OP 1 engraver outline
M6 T16 G43; Drag engraver
o110 while [#50 LE 5]
G10 L2 P2 X[#5221] Y[#5222 -23* #50] Z[#5223]
G55
o100 call
#50 = [#50 + 1]
o110 endwhile
M2
However, my last tool path was a 10mm endmill to cut the contour, and I just reused the engraved path and added G42 to cutter comp it. This errored out with Linuxcnc throwing this message.
Here is the code...
o100 Sub
G0 X-10 Y0
G0 Z5
G01 Z-2.5 F100
G01 X0 Y0
G01 Y-14.5 F1000
G01 X10.5 Y-20
G01 X21
G01 X30 Y-14.5
G01 Y0
G01 X0
G01 Z-5.5 F100
G01 X0 Y0
G01 Y-14.5 F1000
G01 X10.5 Y-20
G01 X21
G01 X30 Y-14.5
G01 Y0
G01 X0
G01 Z-7.75 F100
G01 X0 Y0
G01 Y-14.5 F1000
G01 X10.5 Y-20
G01 X21
G01 X30 Y-14.5
G01 Y0
G01 X0
G01 Z-10.5 F100
G01 X0 Y0
G01 Y-14.5 F1000
G01 X10.5 Y-20
G01 X21
G01 X30 Y-14.5
G01 Y0
G01 X0
G0 Z50
o100 endsub
G17 G21 G40 G54 G90
M6 T10 G43; 10mm end mill
G42
G0 X-10 Y0
G0 Z50
M1
S3000 M3
G4 P4
#50 = 0
G55
o100 call
#50 = [#50 + 1]
o110 endwhile
M5 M9 G40
M2
Is this just a simple error on my side? I didn't find anything in the reference doc's on cutter comp and work offsets not working together.
Cheers,
Mark
o100 Sub
G0 X0 Y0
G0 Z5
G01 Z-2 F100
G01 Y-14.5 F1000
G01 X10.5 Y-20
G01 X21
G01 X30 Y-14.5
G01 Y0
G01 X0
G0 Z50
o100 endsub
#50 = 0
G17 G21 G54 G90
G55
o100 call
#50 = [#50 + 1]
o110 endwhile
M2
Here is the code...
o100 Sub
G0 X-10 Y0
G0 Z5
G01 Z-2.5 F100
G01 X0 Y0
G01 Y-14.5 F1000
G01 X10.5 Y-20
G01 X21
G01 X30 Y-14.5
G01 Y0
G01 X0
G01 Z-5.5 F100
G01 X0 Y0
G01 Y-14.5 F1000
G01 X10.5 Y-20
G01 X21
G01 X30 Y-14.5
G01 Y0
G01 X0
G01 Z-7.75 F100
G01 X0 Y0
G01 Y-14.5 F1000
G01 X10.5 Y-20
G01 X21
G01 X30 Y-14.5
G01 Y0
G01 X0
G01 Z-10.5 F100
G01 X0 Y0
G01 Y-14.5 F1000
G01 X10.5 Y-20
G01 X21
G01 X30 Y-14.5
G01 Y0
G01 X0
G0 Z50
o100 endsub
G17 G21 G40 G54 G90
G42
G0 X-10 Y0
G0 Z50
M1
S3000 M3
G4 P4
#50 = 0
G55
o100 call
#50 = [#50 + 1]
o110 endwhile
M5 M9 G40
M2
Cheers,
Mark
- andrax
- Thank you received: 84
8 months 2 weeks ago #343051
by andrax
Replied by andrax on topic Error combining cutter compensation (G41/42) with work offset (G55)
You're missing a G40.
- RotarySMP
- Topic Author
8 months 2 weeks ago #343070
by RotarySMP
Replied by RotarySMP on topic Error combining cutter compensation (G41/42) with work offset (G55)
There is one at the end Should there be another?
- andrax
8 months 2 weeks ago #343073
by andrax
No, G40 must come first.A change is only possible without tool compensation.
G40
G52
G40
G52
- RotarySMP
- Topic Author
8 months 2 weeks ago #343086
by RotarySMP
Thanks for that.
