Feedrate changes not affecting Z plunge rate
  • scsmith1451
  • scsmith1451's Avatar Topic Author
  • Premium Member
  • Premium Member
29 Oct 2026 18:25 #350538 by scsmith1451
Hi All;
I'm trying to write a surfacing program that slows the plunge rate of the spindle. I've tried:
G0 Z-0.005 F3
and
F3
G0 Z-0.005
Neither change the feed rate of the plunge. However, when using G38.2 combined with an F3 in a probing routine, the spindle slows as expected.
Does spindle plunge rate not respond to the Fn modal command or is there something that I'm missing?
29 Oct 2026 18:30 #350539 by tuxcnc
G0 is rapid, and not uses F value.
Use G1 F3.
The following user(s) said Thank You: scsmith1451
