G03 problem
- Nick
- Thank you received: 11
20 Jan 2011 08:33 #6782
by Nick
G03 problem was created by Nick
Hi there!
I'm one of developers gcodetools - extension for Inkscape, and some of the users reported me about bad Gcode.
Error comes up at the 43th line of attached Gcode. EMC starts to cut huge arc (outer part) instead of small part of it. What can be wrong? I've checked it at the piece of paper and saw no error
Here's the part of the Gcode. Error shows at the last line.
Strange thing that this error is not shown in the Axis preview and appears only during machining.
Thanks in advance
(Header)
(Generated by gcodetools from Inkscape.)
(Using default header. To add your own header create file "header" in the output dir.)
M3
(Header end.)
G21 (All units in mm)
G00 Z5.000000
G00 X67.630205 Y64.835996
G03 X61.419853 Y58.112817 Z-1.419551 I0.269567 J-3.261068
G03 X61.214101 Y58.075595 Z-1.319578 I0.371130 J-2.638719
G03 X61.191611 Y58.064341 Z-1.278559 I20592.241225 J-41151.968089
...Strange thing that this error is not shown in the Axis preview and appears only during machining.
Thanks in advance
Attachment output.ngc not found
- BigJohnT
- Thank you received: 994
20 Jan 2011 21:59 - 21 Jan 2011 11:14 #6784
by BigJohnT
Replied by BigJohnT on topic Re:G03 problem
What was I not thinking...
Last edit: 21 Jan 2011 11:14 by BigJohnT.
- psha
- User is blocked
21 Jan 2011 07:57 #6786
by psha
Replied by psha on topic Re:G03 problem
I think this is minial example of this bugAt least i get similar bug
I guess it's somehow related to floating point errors - requested arc length (~10^-2) is very small compared to radius (~10^5).
G00 X61.191611 Y58.064341 Z-1.278559
G03 X61.164566 Y58.050807 Z-1.229220 I47330.301901 J-94585.894741 F400
M2
%I guess it's somehow related to floating point errors - requested arc length (~10^-2) is very small compared to radius (~10^5).
- psha
- User is blocked
21 Jan 2011 09:58 #6787
by psha
Micges pointed me to interp_internals.hh file where is living constant for comparision
git.linuxcnc.org/gitweb?p=emc2.git;a=blo...b7d2a318;hb=HEAD#l50
And further tests show that if |end - start| << 10^-5 * R then it treats it as full circle.
- Nick
21 Jan 2011 12:43 - 21 Jan 2011 12:46 #6795
by Nick
Replied by Nick on topic Re:G03 problem
Thanks a lot for the answer!
I'll fix that in Gcodetools. I have thought that such small arcs are unreasonable but have no reason to replace them by straight lines. Now I have one
Last edit: 21 Jan 2011 12:46 by Nick.
- psha
- User is blocked
21 Jan 2011 12:47 - 21 Jan 2011 12:49 #6796
by psha
Yes, I think it's best solution
[offtopic]
May you catch me in IRC or drop me a mail (shramov dog mexmat dot net)? I've not found your address...
[offtopic]
Last edit: 21 Jan 2011 12:49 by psha.
Time to create page: 0.429 seconds
