tool radius compensation left.
- occesar_0
05 Feb 2011 21:06 #7013
by occesar_0
tool radius compensation left. was created by occesar_0
Hi
I'm trying to cut some pieces in my cnc router, I designed some pieces, in rhinoceros 4.0, after that i did a conversion of format file (.dxf) and then I used the dxf2gcode software to generate the appropriate code.
Well, after making the cut, I realized that the lenghts weren't accurate because of the tool diameter and because of the route followed (center), so I tried to change the g code and use G41 tool radius compensation left.
dxf2gcode had one option to use the tool radius compensation, but it doesn't work because it changes the shape of my figures, I don't know why.
So I start to edit the program by myself and I used the examples in the g code manual, but every time that I wanted to run in emc2, I got a lot of errors maybe because of the program structure.
Does somebody knows how to change from G40 to G41?
- BigJohnT
- Thank you received: 994
05 Feb 2011 23:56 #7015
by BigJohnT
Replied by BigJohnT on topic Re:tool radius compensation left.
It is very hard to guess what you might be doing wrong without the errors and perhaps the snippet of code that caused the error. My SWAG is you didn't lead into the cut properly.
I suggest reading this chapter in the manual.
www.linuxcnc.org/docview/html/gcode_tool_compensation.html
- occesar_0
07 Feb 2011 18:45 #7053
by occesar_0
Replied by occesar_0 on topic Re:tool radius compensation left.
When I write G41 instead of G40, i got this error message:
"Length of cutter compensation entry move is not greater than the tool radius"
I do understand what it means, but after do some changes, the same happens again.
Seems to be that my program is reading some parameter, which is not in the program structure.
I attached the file, I need some idea please .
By the way, my T1 diameter is 1/8"
Attachment paleta.ngc not found
- BigJohnT
07 Feb 2011 21:31 #7058
by BigJohnT
I didn't see where G41 was in your program... I'm guessing again your getting gouging errors with lots of small moves although I can't test it at the moment...
- occesar_0
09 Feb 2011 18:52 #7098
by occesar_0
Ready! I was missing the entry mode.
Thanks a lot big john
- piasdom
- User is blocked
26 May 2011 15:29 - 26 May 2011 17:15 #10093
by piasdom
Replied by piasdom on topic Re:tool radius compensation left.
why does my g42 cut the outside path instead of inside ?
if i use g41 it goes to the inside of my dim. i've read
www.linuxcnc.org/docview/html/gcode_tool...-Radius-Compensation
and can't understand dat
. the lead-in looks like it is out of the pocket.(but then it doesn't show z)
Attachment OFFSET.ngc not found
Last edit: 26 May 2011 17:15 by piasdom.
Time to create page: 0.093 seconds
