New Project Iso 14649 Ap2 - StepNc
22 Mar 2011 19:35 #8003 by meduag
New Project Iso 14649 Ap2 - StepNc was created by meduag
:huh: Hi,
I'm working on a project to modify the EMC2 to accept the code in ISO 14649 format STEPNC AP21.
Or if it is possible work in a plug for the acceptance EMC2 code format of ISO 14649 STEPNC AP21.
I'm new to the subject CNC, but I love this world of linux and EMC2
I give thanks to who can help me ;) ;)
22 Mar 2011 23:20 #8014 by BigJohnT
Replied by BigJohnT on topic Re:New Project Iso 14649 Ap2 - StepNc
It would quite possibly be easier to just write a python script to change what is different... have you examined what the differences are?
23 Mar 2011 01:11 #8015 by andypugh
Replied by andypugh on topic Re:New Project Iso 14649 Ap2 - StepNc
It's utterly different:
www.steptools.com/support/stdev_docs/exp...toolpath_out_stp.txt
A new interpreter would be needed, but should be easy to integrate (relative to the difficulty of creating it)
23 Mar 2011 11:03 #8025 by BigJohnT
Almost resembles conversational g code somewhat but it sure is different.
What kind of machine uses this?
30 Mar 2011 17:22 - 30 Mar 2011 17:39 #8289 by meduag
Replied by meduag on topic Re:New Project Iso 14649 Ap21 - StepNc
Hi B)
the project, that I am working is
"Development of a Standard CNC Compliant with STEP-NC Based on Advanced Machine Controller (EMC)"
in portuguese
"Desenvolvimento de um CNC Aderente à Norma STEP-NC Baseado no Controlador de Máquina Avançado (EMC)"
I work with:
Norma ISO 14649 (STEP-NC)
Here you can watch a video:
the machine I use is a 3-axis milling machine, a video sample here (I build a machine like)
Here is an example of code in format Step-Nc Ap21
docs.google.com/document/d/1h_i0ki-w6LDu...Ak/edit?hl=en&pli=1#
then, in other words, I want to modify the EMC2 code to take STEP-NC format and convert to G code.
I want to know if is possible to make a plugin for EMC2, without directly modifying the EMC2.
find more information on this link
code.google.com/p/iso-14649-toolkit/
www.step-nc.org/index.htm
www.steptools.com/
thank you very much for the help
pdt:
I'm not very good with English, but I do know, Spanish and Portuguese
thanks, gracias, obrigado.
Last edit: 30 Mar 2011 17:39 by meduag.
Time to create page: 0.576 seconds
