Is there a precision command for movements?
- dibella
30 Mar 2011 17:12 - 30 Mar 2011 17:43 #8288
by dibella
Is there a precision command for movements? was created by dibella
I am running EMC2 on a laser machine. Previously, with the 30 year old Bosch Controller, it worked perfectly. It went exactly where the program code said.
Now, it rounds up. The faster it works, the more it rounds up. And it even shows on the monitor that it doesn't follow the program code.
Is there a way to force the software to avoid this?
It is absolutely not a machine problem. In the past, we ran the machine at 5 times the usual speed, and it moved exactly it should. Not it doesn't do it even at the normal speed.
I also checked: My NC Code header contains G61. I don't know if that is enough, and if I also need G61.1 and where.
Thanks in advance!
Thanks in advance!
Last edit: 30 Mar 2011 17:43 by dibella.
- BigJohnT
- Thank you received: 994
30 Mar 2011 17:25 #8290
by BigJohnT
Replied by BigJohnT on topic Re:Is there a precision command for movements?
A must read chapter for "new to EMC" folks...
www.linuxcnc.org/docview/html/common_User_Concepts.html
- cncbasher
- Thank you received: 202
30 Mar 2011 18:57 #8291
by cncbasher
Replied by cncbasher on topic Re:Is there a precision command for movements?
i would suggest you check you motor drivers ( again i presume it is using servo drives , but please correct if i am wrong ) and configuration of analog input drives and signal voltages , this type of problem suggests some miss tuning or follow error etc
you say it ' rounds up' can you give some specifics etc
even changing from your old controller to emc would require your origional drive input to be adjusted to match emc2
can you give some information on pc setup and how you interfaced to emc2
so the problem can be narrowed down for you
- BigJohnT
30 Mar 2011 19:12 - 30 Mar 2011 19:13 #8292
by BigJohnT
The problem is usually that a new user has not read the few pages I linked to regarding Programming the Planner and do not understand what the result of using G64 vs other trajectory control commands.
I see the edit now that he is using G61 so that indicates a mechanical/tuning issue.
Last edit: 30 Mar 2011 19:13 by BigJohnT.
- dibella
30 Mar 2011 19:21 #8293
by dibella
Replied by dibella on topic Re:Is there a precision command for movements?
I had a Bosch Micro 8 controller on the laser machine. The servo drives are also Bosch.
I suspect that the Micro 8 had a specific parameter configuration on how to handle lines and arcs of different sizes.
I'll try to get information from the manufacturer, since the guys who installed EMC2 (with interface boards they developed) also are new to this situation.
If I still need help I will appear again.
Thanks a lot!
Thanks a lot!
- BigJohnT
30 Mar 2011 19:29 #8294
by BigJohnT
If you program G61 that is exact path mode which means it will follow the exact path no matter how slow it has to go to do so. The screen is not updated in real time so you can't go by the backplot especially if it is zoomed in a lot.
- dibella
30 Mar 2011 19:39 #8295
by dibella
Dumb question:
I have G61 twice in my NC Code. Does the second one turn off the command? Because it really doesn't follow the programmed path and instead to make a corner of 90 degrees, it makes an arc at the end of one line, before it makes the following straight line.
Maybe I should delete one G91 and try what happens.
- BigJohnT
30 Mar 2011 19:54 #8296
by BigJohnT
A second G61 will not turn off the first G61. If your machine does not follow the exact path (can't look at the screen because it is not updated in real time ) something is wrong with your machine and you might have a huge following error or some other cause.
- BigJohnT
30 Mar 2011 19:55 #8297
by BigJohnT
Are these G0 moves that make an arc?
- dibella
30 Mar 2011 20:11 #8298
by dibella
No.
G0 is used for fast moving. G1 for moving while a tool is on and for lines. G2 for arcs with tool on.
If I have a small square, it doesn't cut perfectly at 90 degrees. The difference is visible. At the end of a line, it doesn't go straight to the beginning of the next line, at the point that should be the corner. It makes a small arc. The real corner is outside of the figure it cuts and isn't touched by any line.
I see this one the screen too, but I do not understand, why it happens, if I have G61 at the beginning of the code.
Could it be that due to modifications made to EMC2 to work with our machine, it forgets about G61?
As I understand, G61 is mandatory and should create weird behavior in form of sudden stops.
Time to create page: 1.048 seconds
