Is there a precision command for movements?
30 Mar 2011 21:07 #8301 by BigJohnT
Replied by BigJohnT on topic Re:Is there a precision command for movements?
Are you running a stock version of EMC? if so which one? or has the source code been modified for your machine? If it is the latter you need to contact the person who changed the source code.
G61 is exact path and if needed it will come to a stop to make sure it goes to the endpoint exactly of each move.
30 Mar 2011 21:36 #8303 by dibella
It is a slightly modified EMC2. I am already in touch with the programmer, who also says that G61 should not produce what comes out from the machine.
Let's see if he finds something!
