Which CAD ?
18 May 2011 18:14 #9918 by moghoe
Which CAD ? was created by moghoe
Please ! Can someone suggest some Linux CAD programmes and compatible G-code converter..
Will Inkscape do ?
As a newcomer, I do not intend to cut anything myself, but give G-code to a milling shop.
Thank You ! moghoe
18 May 2011 20:04 #9919 by BigJohnT
Replied by BigJohnT on topic Re:Which CAD ?
QCAD is a fairly good Linux CAD program.
Machine shops will usually work with the CAD drawing and will not want your g code unless you have worked with them for a long time and they know you will be providing code that will run on their machines which is unlikely.
