Axis Simulator opens with realtime error
- jimmyservo
26 May 2011 14:32 #10092
by jimmyservo
Axis Simulator opens with realtime error was created by jimmyservo
Using and old Dell Latitude laptop to practice G-code in simulator only. I installed the latest version of EMC2 from CD, but when I start EMC2 I get an error. Here's a section of the error relating to the realtime module being not permitted:
Starting EMC2...
Starting EMC2 server program: emcsvr
Realtime system did not load
Shutting down and cleaning up EMC2...
Killing task emcsvr, PID=2300
Cleanup done
Debug file information:
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/rtai_hal.ko': -1 Operation not permitted
2300
I am a newbie to the command line, so please keep it simple
Thanks,
jimmyservo
Starting EMC2...
Cleanup done
2300
Thanks,
jimmyservo
- BigJohnT
- Thank you received: 1176
26 May 2011 16:10 #10095
by BigJohnT
Replied by BigJohnT on topic Re:Axis Simulator opens with realtime error
If you install from the liveCD you will get the real time version of the software not the pure simulator. The section of the error is not enough to guess what is wrong. Attach the complete error message as txt file.
Did you create a config or open up one of the sims?
The name of the config can not contain a space...
- jimmyservo
27 May 2011 02:10 #10108
by jimmyservo
Replied by jimmyservo on topic Re:Axis Simulator opens with realtime error
John,
I just picked one of the EMC2 sample configurations (Axis Sim). Here's the complete error message:
Print file information:
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_BIN_DIR=/usr/bin
EMC2_TCL_DIR=/usr/share/emc/tcl
EMC2_SCRIPT_DIR=
EMC2_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/emc2
EMC2_CONFIG_DIR=
EMC2_LANG_DIR=/usr/share/emc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
EMC2_EMCSH=/usr/bin/wish8.5
EMC2 - 2.4.6
Machine configuration directory is '/home/dell/emc2/configs/sim'
Machine configuration file is 'axis.ini'
INIFILE=/home/dell/emc2/configs/sim/axis.ini
PARAMETER_FILE=sim.var
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=halui
DISPLAY=axis
NML_FILE=
Starting EMC2...
Killing task emcsvr, PID=1976
Cleanup done
1976
PID TTY STAT TIME COMMAND
Stopping realtime threads
RTAPI: ERROR: could not open shared memory (errno=2)
HAL: ERROR: rtapi init failed
halcmd: hal_init() failed: -22
NOTE: 'rtapi' kernel module must be loaded
Unloading hal components
ERROR: Module hal_lib does not exist in /proc/modules
ERROR: Module rtapi does not exist in /proc/modules
ERROR: Module rtai_math does not exist in /proc/modules
ERROR: Module rtai_sem does not exist in /proc/modules
ERROR: Module rtai_fifos does not exist in /proc/modules
ERROR: Module rtai_sched does not exist in /proc/modules
ERROR: Module rtai_hal does not exist in /proc/modules
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 2.6.32-122-rtai (root@moses-6core) (gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) ) #rtai SMP Tue Jul 27 12:44:07 CDT 2010 (Ubuntu 2.6.32-122.35.rtai-rtai 2.6.32.11+drm33.2)
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] NSC Geode by NSC
[ 0.000000] Cyrix CyrixInstead
[ 0.000000] Centaur CentaurHauls
[ 0.000000] Transmeta GenuineTMx86
[ 0.000000] Transmeta TransmetaCPU
[ 0.000000] UMC UMC UMC UMC
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000001ffe2800 (usable)
[ 0.000000] BIOS-e820: 000000001ffe2800 - 0000000020000000 (reserved)
[ 0.000000] BIOS-e820: 00000000feda0000 - 00000000fee00000 (reserved)
[ 0.000000] BIOS-e820: 00000000ffb80000 - 0000000100000000 (reserved)
[ 0.000000] DMI 2.3 present.
[ 0.000000] last_pfn = 0x1ffe2 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-CFFFF write-protect
[ 0.000000] D0000-EFFFF uncachable
[ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask FE0000000 write-back
[ 0.000000] 1 base 0FEDA0000 mask FFFFE0000 write-combining
[ 0.000000] 2 disabled
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] e820 update range: 0000000000002000 - 0000000000006000 (usable) ==> (reserved)
[ 0.000000] Scanning 1 areas for low memory corruption
[ 0.000000] modified physical RAM map:
[ 0.000000] modified: 0000000000000000 - 0000000000002000 (usable)
[ 0.000000] modified: 0000000000002000 - 0000000000006000 (reserved)
[ 0.000000] modified: 0000000000006000 - 000000000009fc00 (usable)
[ 0.000000] modified: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] modified: 0000000000100000 - 000000001ffe2800 (usable)
[ 0.000000] modified: 000000001ffe2800 - 0000000020000000 (reserved)
[ 0.000000] modified: 00000000feda0000 - 00000000fee00000 (reserved)
[ 0.000000] modified: 00000000ffb80000 - 0000000100000000 (reserved)
[ 0.000000] initial memory mapped : 0 - 00c00000
[ 0.000000] init_memory_mapping: 0000000000000000-000000001ffe2000
[ 0.000000] Using x86 segment limits to approximate NX protection
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 001fc00000 page 2M
[ 0.000000] 001fc00000 - 001ffe2000 page 4k
[ 0.000000] kernel direct mapping tables up to 1ffe2000 @ 7000-c000
[ 0.000000] RAMDISK: 173a3000 - 18029dad
[ 0.000000] ACPI: RSDP 000fde50 00014 (v00 DELL )
[ 0.000000] ACPI: RSDT 000fde64 00028 (v01 DELL CPi R 27D40107 ASL 00000061)
[ 0.000000] ACPI: FACP 000fde90 00074 (v01 DELL CPi R 27D40107 ASL 00000061)
[ 0.000000] ACPI: DSDT fffe4000 0314E (v01 INT430 SYSFexxx 00001001 MSFT 0100000E)
[ 0.000000] ACPI: FACS 1ffff800 00040
[ 0.000000] 0MB HIGHMEM available.
[ 0.000000] 511MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 1ffe2000
[ 0.000000] low ram: 0 - 1ffe2000
[ 0.000000] node 0 low ram: 00000000 - 1ffe2000
[ 0.000000] node 0 bootmap 00008000 - 0000c000
[ 0.000000] (9 early reservations) ==> bootmem [0000000000 - 001ffe2000]
[ 0.000000] #0 [0000000000 - 0000001000] BIOS data page ==> [0000000000 - 0000001000]
[ 0.000000] #1 [0000001000 - 0000002000] EX TRAMPOLINE ==> [0000001000 - 0000002000]
[ 0.000000] #2 [0000006000 - 0000007000] TRAMPOLINE ==> [0000006000 - 0000007000]
[ 0.000000] #3 [0000100000 - 00008b0db8] TEXT DATA BSS ==> [0000100000 - 00008b0db8]
[ 0.000000] #4 [00173a3000 - 0018029dad] RAMDISK ==> [00173a3000 - 0018029dad]
[ 0.000000] #5 [000009fc00 - 0000100000] BIOS reserved ==> [000009fc00 - 0000100000]
[ 0.000000] #6 [00008b1000 - 00008b419c] BRK ==> [00008b1000 - 00008b419c]
[ 0.000000] #7 [0000007000 - 0000008000] PGTABLE ==> [0000007000 - 0000008000]
[ 0.000000] #8 [0000008000 - 000000c000] BOOTMAP ==> [0000008000 - 000000c000]
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000000 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x0001ffe2
[ 0.000000] HighMem 0x0001ffe2 -> 0x0001ffe2
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[3] active PFN ranges
[ 0.000000] 0: 0x00000000 -> 0x00000002
[ 0.000000] 0: 0x00000006 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x0001ffe2
[ 0.000000] On node 0 totalpages: 130941
[ 0.000000] free_area_init_node: node 0, pgdat c07470e0, node_mem_map c1001000
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3963 pages, LIFO batch:0
[ 0.000000] Normal zone: 992 pages used for memmap
[ 0.000000] Normal zone: 125954 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] SMP: Allowing 1 CPUs, 0 hotplug CPUs
[ 0.000000] Local APIC disabled by BIOS -- you can enable it with "lapic"
[ 0.000000] APIC: disable apic facility
[ 0.000000] nr_irqs_gsi: 16
[ 0.000000] Allocating PCI resources starting at 20000000 (gap: 20000000:deda0000)
[ 0.000000] NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:1 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 24 pages/cpu @c1800000 s74936 r0 d23368 u4194304
[ 0.000000] pcpu-alloc: s74936 r0 d23368 u4194304 alloc=1*4194304
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129917
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-122-rtai root=UUID=79967b90-e2f5-4361-956e-3919f92e2e45 ro quiet splash
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Enabling fast FPU save and restore... done.
[ 0.000000] Enabling unmasked SIMD FPU exception support... done.
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 2620840 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (00000000:00000000)
[ 0.000000] Memory: 495624k/524168k available (4539k kernel code, 27900k reserved, 1928k data, 620k init, 0k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff1e000 - 0xfffff000 ( 900 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xe07e2000 - 0xff7fe000 ( 496 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xdffe2000 ( 511 MB)
[ 0.000000] .init : 0xc0751000 - 0xc07ec000 ( 620 kB)
[ 0.000000] .data : 0xc056ecbc - 0xc0750e68 (1928 kB)
[ 0.000000] .text : 0xc0100000 - 0xc056ecbc (4539 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] SLUB: Genslabs=13, HWalign=128, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:2304 nr_irqs:256
[ 0.000000] I-pipe 2.6-03: pipeline enabled.
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 2392.689 MHz processor.
[ 0.008008] Calibrating delay loop (skipped), value calculated using timer frequency.. 4785.37 BogoMIPS (lpj=9570756)
[ 0.008037] Security Framework initialized
[ 0.008070] AppArmor: AppArmor initialized
[ 0.008083] Mount-cache hash table entries: 512
[ 0.008293] Initializing cgroup subsys ns
[ 0.008302] Initializing cgroup subsys cpuacct
[ 0.008311] Initializing cgroup subsys memory
[ 0.008327] Initializing cgroup subsys devices
[ 0.008332] Initializing cgroup subsys freezer
[ 0.008337] Initializing cgroup subsys net_cls
[ 0.008374] CPU: Trace cache: 12K uops, L1 D cache: 8K
[ 0.008381] CPU: L2 cache: 512K
[ 0.008385] CPU: Hyper-Threading is disabled
[ 0.008392] mce: CPU supports 4 MCE banks
[ 0.008417] Performance Events: no PMU driver, software events only.
[ 0.008429] Checking 'hlt' instruction... OK.
[ 0.025347] SMP alternatives: switching to UP code
[ 0.039164] Freeing SMP alternatives: 31k freed
[ 0.039199] ACPI: Core revision 20090903
[ 0.093034] ACPI: setting ELCR to 0200 (from 0800)
[ 0.095432] ftrace: converting mcount calls to 0f 1f 44 00 00
[ 0.095443] ftrace: allocating 21003 entries in 42 pages
[ 0.109263] Enabling APIC mode: Flat. Using 0 I/O APICs
[ 0.109269] weird, boot CPU (#0) not listed by the BIOS.
[ 0.109271] SMP motherboard not detected.
[ 0.109275] Local APIC not detected. Using dummy APIC emulation.
[ 0.109277] SMP disabled
[ 0.109589] Brought up 1 CPUs
[ 0.109594] Total of 1 processors activated (4785.37 BogoMIPS).
[ 0.109949] CPU0 attaching NULL sched-domain.
[ 0.110177] devtmpfs: initialized
[ 0.110682] regulator: core version 0.5
[ 0.110756] NET: Registered protocol family 16
[ 0.110939] EISA bus registered
[ 0.110952] ACPI: bus type pci registered
[ 0.137840] PCI: PCI BIOS revision 2.10 entry at 0xfbfee, last bus=2
[ 0.137844] PCI: Using configuration type 1 for base access
[ 0.139073] bio: create slab <bio-0> at 0
[ 0.139813] ACPI: EC: Look up EC in DSDT
[ 0.181363] ACPI: Interpreter enabled
[ 0.181368] ACPI: (supports S0 S5)
[ 0.181386] ACPI: Using PIC for interrupt routing
[ 0.235706] ACPI: Power Resource [PADA] (on)
[ 0.242944] ACPI: ACPI Dock Station Driver: 1 docks/bays found
[ 0.266886] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.266961] pci 0000:00:00.0: reg 10 32bit mmio pref: [0xe8000000-0xebffffff]
[ 0.267120] pci 0000:00:1d.0: reg 20 io port: [0xbf80-0xbf9f]
[ 0.267190] pci 0000:00:1d.2: reg 20 io port: [0xbf20-0xbf3f]
[ 0.267318] pci 0000:00:1f.0: quirk: region 0800-087f claimed by ICH4 ACPI/GPIO/TCO
[ 0.267324] pci 0000:00:1f.0: quirk: region 0880-08bf claimed by ICH4 GPIO
[ 0.267356] pci 0000:00:1f.1: reg 10 io port: [0x1f0-0x1f7]
[ 0.267365] pci 0000:00:1f.1: reg 14 io port: [0x3f4-0x3f7]
[ 0.267374] pci 0000:00:1f.1: reg 18 io port: [0x170-0x177]
[ 0.267383] pci 0000:00:1f.1: reg 1c io port: [0x374-0x377]
[ 0.267392] pci 0000:00:1f.1: reg 20 io port: [0xbfa0-0xbfaf]
[ 0.267402] pci 0000:00:1f.1: reg 24 32bit mmio: [0x000000-0x0003ff]
[ 0.267446] pci 0000:00:1f.5: reg 10 io port: [0xd800-0xd8ff]
[ 0.267455] pci 0000:00:1f.5: reg 14 io port: [0xdc80-0xdcbf]
[ 0.267521] pci 0000:00:1f.6: reg 10 io port: [0xd400-0xd4ff]
[ 0.267530] pci 0000:00:1f.6: reg 14 io port: [0xdc00-0xdc7f]
[ 0.267611] pci 0000:01:00.0: reg 10 32bit mmio: [0xfc000000-0xfcffffff]
[ 0.267619] pci 0000:01:00.0: reg 14 32bit mmio pref: [0xe0000000-0xe7ffffff]
[ 0.267629] pci 0000:01:00.0: reg 18 32bit mmio pref: [0xdff80000-0xdfffffff]
[ 0.267649] pci 0000:01:00.0: reg 30 32bit mmio pref: [0x80000000-0x8001ffff]
[ 0.267717] pci 0000:00:01.0: bridge io port: [0xc000-0xcfff]
[ 0.267722] pci 0000:00:01.0: bridge 32bit mmio: [0xfc000000-0xfdffffff]
[ 0.267728] pci 0000:00:01.0: bridge 32bit mmio pref: [0xd8000000-0xe7ffffff]
[ 0.267771] pci 0000:02:00.0: reg 10 io port: [0xec80-0xecff]
[ 0.267780] pci 0000:02:00.0: reg 14 32bit mmio: [0xf8fffc00-0xf8fffc7f]
[ 0.267809] pci 0000:02:00.0: reg 30 32bit mmio pref: [0xf9000000-0xf901ffff]
[ 0.267832] pci 0000:02:00.0: supports D1 D2
[ 0.267836] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.267842] pci 0000:02:00.0: PME# disabled
[ 0.267883] pci 0000:02:01.0: reg 10 32bit mmio: [0x000000-0x000fff]
[ 0.267907] pci 0000:02:01.0: supports D1 D2
[ 0.267910] pci 0000:02:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.267916] pci 0000:02:01.0: PME# disabled
[ 0.267958] pci 0000:02:01.1: reg 10 32bit mmio: [0x000000-0x000fff]
[ 0.267982] pci 0000:02:01.1: supports D1 D2
[ 0.267985] pci 0000:02:01.1: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.268007] pci 0000:02:01.1: PME# disabled
[ 0.268052] pci 0000:02:01.2: reg 10 32bit mmio: [0xf8fff000-0xf8fff7ff]
[ 0.268061] pci 0000:02:01.2: reg 14 32bit mmio: [0xf8ff8000-0xf8ffbfff]
[ 0.268113] pci 0000:02:01.2: supports D2
[ 0.268116] pci 0000:02:01.2: PME# supported from D2 D3hot
[ 0.268122] pci 0000:02:01.2: PME# disabled
[ 0.268181] pci 0000:00:1e.0: transparent bridge
[ 0.268187] pci 0000:00:1e.0: bridge io port: [0xe000-0xffff]
[ 0.268193] pci 0000:00:1e.0: bridge 32bit mmio: [0xf4000000-0xfbffffff]
[ 0.268251] pci_bus 0000:00: on NUMA node 0
[ 0.268258] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.268407] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.AGP_._PRT]
[ 0.268441] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCIE._PRT]
[ 0.314235] ACPI: PCI Interrupt Link [LNKA] (IRQs 9 10 *11)
[ 0.314664] ACPI: PCI Interrupt Link [LNKB] (IRQs 5 7) *11
[ 0.315087] ACPI: PCI Interrupt Link [LNKC] (IRQs 9 10 *11)
[ 0.315511] ACPI: PCI Interrupt Link [LNKD] (IRQs 5 7 9 10 *11)
[ 0.315756] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.315764] vgaarb: loaded
[ 0.315972] SCSI subsystem initialized
[ 0.316106] libata version 3.00 loaded.
[ 0.316214] usbcore: registered new interface driver usbfs
[ 0.316239] usbcore: registered new interface driver hub
[ 0.316286] usbcore: registered new device driver usb
[ 0.316502] ACPI: WMI: Mapper loaded
[ 0.316506] PCI: Using ACPI for IRQ routing
[ 0.316714] NetLabel: Initializing
[ 0.316718] NetLabel: domain hash size = 128
[ 0.316720] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.316742] NetLabel: unlabeled traffic allowed by default
[ 0.316803] Switching to clocksource tsc
[ 0.319795] AppArmor: AppArmor Filesystem Enabled
[ 0.319822] pnp: PnP ACPI init
[ 0.319853] ACPI: bus type pnp registered
[ 0.362474] pnp 00:02: io resource (0x800-0x805) overlaps 0000:00:1f.0 BAR 13 (0x800-0x87f), disabling
[ 0.362481] pnp 00:02: io resource (0x808-0x80f) overlaps 0000:00:1f.0 BAR 13 (0x800-0x87f), disabling
[ 0.362605] pnp 00:03: io resource (0x806-0x807) overlaps 0000:00:1f.0 BAR 13 (0x800-0x87f), disabling
[ 0.362612] pnp 00:03: io resource (0x810-0x85f) overlaps 0000:00:1f.0 BAR 13 (0x800-0x87f), disabling
[ 0.362617] pnp 00:03: io resource (0x860-0x87f) overlaps 0000:00:1f.0 BAR 13 (0x800-0x87f), disabling
[ 0.363653] pnp 00:04: io resource (0xf000-0xf0fe) overlaps 0000:00:1e.0 BAR 13 (0xe000-0xffff), disabling
[ 0.363659] pnp 00:04: io resource (0xf100-0xf1fe) overlaps 0000:00:1e.0 BAR 13 (0xe000-0xffff), disabling
[ 0.363664] pnp 00:04: io resource (0xf200-0xf2fe) overlaps 0000:00:1e.0 BAR 13 (0xe000-0xffff), disabling
[ 0.363669] pnp 00:04: io resource (0xf400-0xf4fe) overlaps 0000:00:1e.0 BAR 13 (0xe000-0xffff), disabling
[ 0.363674] pnp 00:04: io resource (0xf500-0xf5fe) overlaps 0000:00:1e.0 BAR 13 (0xe000-0xffff), disabling
[ 0.363679] pnp 00:04: io resource (0xf600-0xf6fe) overlaps 0000:00:1e.0 BAR 13 (0xe000-0xffff), disabling
[ 0.363684] pnp 00:04: io resource (0xf800-0xf8fe) overlaps 0000:00:1e.0 BAR 13 (0xe000-0xffff), disabling
[ 0.363689] pnp 00:04: io resource (0xf900-0xf9fe) overlaps 0000:00:1e.0 BAR 13 (0xe000-0xffff), disabling
[ 0.363694] pnp 00:04: io resource (0xfa00-0xfafe) overlaps 0000:00:1e.0 BAR 13 (0xe000-0xffff), disabling
[ 0.363699] pnp 00:04: io resource (0xfc00-0xfcfe) overlaps 0000:00:1e.0 BAR 13 (0xe000-0xffff), disabling
[ 0.363704] pnp 00:04: io resource (0xfd00-0xfdfe) overlaps 0000:00:1e.0 BAR 13 (0xe000-0xffff), disabling
[ 0.363709] pnp 00:04: io resource (0xfe00-0xfefe) overlaps 0000:00:1e.0 BAR 13 (0xe000-0xffff), disabling
[ 0.363714] pnp 00:04: mem resource (0xfa000000-0xfbffffff) overlaps 0000:00:1e.0 BAR 14 (0xf4000000-0xfbffffff), disabling
[ 0.435686] pnp: PnP ACPI: found 16 devices
[ 0.435691] ACPI: ACPI bus type pnp unregistered
[ 0.435699] PnPBIOS: Disabled by ACPI PNP
[ 0.435719] system 00:00: iomem range 0x0-0x9fbff could not be reserved
[ 0.435724] system 00:00: iomem range 0x9fc00-0x9ffff could not be reserved
[ 0.435730] system 00:00: iomem range 0xc0000-0xcffff could not be reserved
[ 0.435735] system 00:00: iomem range 0xe0000-0xfffff could not be reserved
[ 0.435740] system 00:00: iomem range 0x100000-0x1ffeffff could not be reserved
[ 0.435745] system 00:00: iomem range 0x1fff0000-0x1fffffff has been reserved
[ 0.435749] system 00:00: iomem range 0xfeda0000-0xfedfffff has been reserved
[ 0.435754] system 00:00: iomem range 0xfff80000-0xffffffff has been reserved
[ 0.435765] system 00:02: ioport range 0x4d0-0x4d1 has been reserved
[ 0.435774] system 00:03: ioport range 0x880-0x8bf has been reserved
[ 0.435778] system 00:03: ioport range 0x8c0-0x8df has been reserved
[ 0.435784] system 00:03: ioport range 0x8e0-0x8ff has been reserved
[ 0.435800] system 00:09: ioport range 0x900-0x91f has been reserved
[ 0.435804] system 00:09: ioport range 0x3f0-0x3f1 has been reserved
[ 0.435816] system 00:0e: ioport range 0xbf40-0xbf5f has been reserved
[ 0.435825] system 00:0f: iomem range 0xfebffc00-0xfebfffff has been reserved
[ 0.470619] pci 0000:01:00.0: BAR 6: no parent found for of device [0x80000000-0x8001ffff]
[ 0.470626] pci 0000:02:00.0: BAR 6: address space collision on of device [0xf9000000-0xf901ffff]
[ 0.470657] pci 0000:00:01.0: PCI bridge, secondary bus 0000:01
[ 0.470662] pci 0000:00:01.0: IO window: 0xc000-0xcfff
[ 0.470668] pci 0000:00:01.0: MEM window: 0xfc000000-0xfdffffff
[ 0.470674] pci 0000:00:01.0: PREFETCH window: 0xd8000000-0xe7ffffff
[ 0.470694] pci 0000:02:01.0: CardBus bridge, secondary bus 0000:03
[ 0.470697] pci 0000:02:01.0: IO window: 0x00e000-0x00e0ff
[ 0.470703] pci 0000:02:01.0: IO window: 0x00e400-0x00e4ff
[ 0.470709] pci 0000:02:01.0: PREFETCH window: 0x20000000-0x23ffffff
[ 0.470715] pci 0000:02:01.0: MEM window: 0xf4000000-0xf7ffffff
[ 0.470721] pci 0000:02:01.1: CardBus bridge, secondary bus 0000:07
[ 0.470725] pci 0000:02:01.1: IO window: 0x00e800-0x00e8ff
[ 0.470731] pci 0000:02:01.1: IO window: 0x00f000-0x00f0ff
[ 0.470737] pci 0000:02:01.1: PREFETCH window: 0x24000000-0x27ffffff
[ 0.470743] pci 0000:02:01.1: MEM window: 0x2c000000-0x2fffffff
[ 0.470748] pci 0000:00:1e.0: PCI bridge, secondary bus 0000:02
[ 0.470753] pci 0000:00:1e.0: IO window: 0xe000-0xffff
[ 0.470761] pci 0000:00:1e.0: MEM window: 0xf4000000-0xfbffffff
[ 0.470767] pci 0000:00:1e.0: PREFETCH window: 0x20000000-0x29ffffff
[ 0.470792] pci 0000:00:1e.0: setting latency timer to 64
[ 0.470803] pci 0000:02:01.0: enabling device (0000 -> 0003)
[ 0.471399] ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 11
[ 0.471404] PCI: setting IRQ 11 as level-triggered
[ 0.471410] pci 0000:02:01.0: PCI INT A -> Link[LNKD] -> GSI 11 (level, low) -> IRQ 11
[ 0.471426] pci 0000:02:01.1: enabling device (0000 -> 0003)
[ 0.471433] pci 0000:02:01.1: PCI INT A -> Link[LNKD] -> GSI 11 (level, low) -> IRQ 11
[ 0.471443] pci_bus 0000:00: resource 0 io: [0x00-0xffff]
[ 0.471447] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffff]
[ 0.471451] pci_bus 0000:01: resource 0 io: [0xc000-0xcfff]
[ 0.471455] pci_bus 0000:01: resource 1 mem: [0xfc000000-0xfdffffff]
[ 0.471459] pci_bus 0000:01: resource 2 pref mem [0xd8000000-0xe7ffffff]
[ 0.471463] pci_bus 0000:02: resource 0 io: [0xe000-0xffff]
[ 0.471467] pci_bus 0000:02: resource 1 mem: [0xf4000000-0xfbffffff]
[ 0.471471] pci_bus 0000:02: resource 2 pref mem [0x20000000-0x29ffffff]
[ 0.471474] pci_bus 0000:02: resource 3 io: [0x00-0xffff]
[ 0.471478] pci_bus 0000:02: resource 4 mem: [0x000000-0xffffffff]
[ 0.471482] pci_bus 0000:03: resource 0 io: [0xe000-0xe0ff]
[ 0.471486] pci_bus 0000:03: resource 1 io: [0xe400-0xe4ff]
[ 0.471490] pci_bus 0000:03: resource 2 pref mem [0x20000000-0x23ffffff]
[ 0.471494] pci_bus 0000:03: resource 3 mem: [0xf4000000-0xf7ffffff]
[ 0.471498] pci_bus 0000:07: resource 0 io: [0xe800-0xe8ff]
[ 0.471501] pci_bus 0000:07: resource 1 io: [0xf000-0xf0ff]
[ 0.471505] pci_bus 0000:07: resource 2 pref mem [0x24000000-0x27ffffff]
[ 0.471509] pci_bus 0000:07: resource 3 mem: [0x2c000000-0x2fffffff]
[ 0.471564] NET: Registered protocol family 2
[ 0.471712] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.472126] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.472245] TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.472349] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.472352] TCP reno registered
[ 0.472466] NET: Registered protocol family 1
[ 0.472545] pci 0000:01:00.0: Boot video device
[ 0.472867] Scanning for low memory corruption every 60 seconds
[ 0.473028] audit: initializing netlink socket (disabled)
[ 0.473049] type=2000 audit(1306443287.471:1): initialized
[ 0.481035] Trying to unpack rootfs image as initramfs...
[ 0.491710] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.493791] VFS: Disk quotas dquot_6.5.2
[ 0.493878] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.499312] fuse init (API version 7.13)
[ 0.499502] msgmni has been set to 968
[ 0.499881] alg: No test for stdrng (krng)
[ 0.499991] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.499997] io scheduler noop registered
[ 0.500000] io scheduler anticipatory registered
[ 0.500003] io scheduler deadline registered
[ 0.500060] io scheduler cfq registered (default)
[ 0.500233] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.500272] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.500388] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
[ 0.501149] ACPI: Lid Switch [LID]
[ 0.501215] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 0.501223] ACPI: Power Button [PBTN]
[ 0.501287] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2
[ 0.501292] ACPI: Sleep Button [SBTN]
[ 0.507978] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.508105] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.508679] 00:0d: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.509419] ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 7
[ 0.509425] PCI: setting IRQ 7 as level-triggered
[ 0.509432] serial 0000:00:1f.6: PCI INT B -> Link[LNKB] -> GSI 7 (level, low) -> IRQ 7
[ 0.509442] serial 0000:00:1f.6: PCI INT B disabled
[ 0.510869] brd: module loaded
[ 0.511240] isapnp: Scanning for PnP cards...
[ 0.517172] loop: module loaded
[ 0.517342] input: Macintosh mouse button emulation as /devices/virtual/input/input3
[ 0.517513] ata_piix 0000:00:1f.1: version 2.13
[ 0.517533] ata_piix 0000:00:1f.1: enabling device (0005 -> 0007)
[ 0.518145] ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 11
[ 0.518152] ata_piix 0000:00:1f.1: PCI INT A -> Link[LNKA] -> GSI 11 (level, low) -> IRQ 11
[ 0.518229] ata_piix 0000:00:1f.1: setting latency timer to 64
[ 0.523601] scsi0 : ata_piix
[ 0.567302] scsi1 : ata_piix
[ 0.569203] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xbfa0 irq 14
[ 0.569208] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xbfa8 irq 15
[ 0.569853] Fixed MDIO Bus: probed
[ 0.569913] PPP generic driver version 2.4.2
[ 0.570023] tun: Universal TUN/TAP device driver, 1.6
[ 0.570026] tun: (C) 1999-2004 Max Krasnyansky <This email address is being protected from spambots. You need JavaScript enabled to view it.>
[ 0.570176] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.570202] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.570223] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.570286] uhci_hcd 0000:00:1d.0: PCI INT A -> Link[LNKA] -> GSI 11 (level, low) -> IRQ 11
[ 0.570301] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 0.570307] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 0.570371] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 1
[ 0.570410] uhci_hcd 0000:00:1d.0: irq 11, io base 0x0000bf80
[ 0.570569] usb usb1: configuration #1 chosen from 1 choice
[ 0.570612] hub 1-0:1.0: USB hub found
[ 0.570631] hub 1-0:1.0: 2 ports detected
[ 0.575604] ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 11
[ 0.575615] uhci_hcd 0000:00:1d.2: PCI INT C -> Link[LNKC] -> GSI 11 (level, low) -> IRQ 11
[ 0.575635] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 0.575641] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 0.575782] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 2
[ 0.575819] uhci_hcd 0000:00:1d.2: irq 11, io base 0x0000bf20
[ 0.575992] usb usb2: configuration #1 chosen from 1 choice
[ 0.576035] hub 2-0:1.0: USB hub found
[ 0.576051] hub 2-0:1.0: 2 ports detected
[ 0.576212] PNP: PS/2 Controller [PNP0303:KBC,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 0.584170] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.584191] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.584453] mice: PS/2 mouse device common for all mice
[ 0.584779] rtc_cmos 00:07: rtc core: registered rtc_cmos as rtc0
[ 0.584802] rtc0: alarms up to one day, 114 bytes nvram
[ 0.584995] device-mapper: uevent: version 1.0.3
[ 0.585210] device-mapper: ioctl: 4.15.0-ioctl (2009-04-01) initialised: This email address is being protected from spambots. You need JavaScript enabled to view it.
[ 0.587398] device-mapper: multipath: version 1.1.0 loaded
[ 0.587406] device-mapper: multipath round-robin: version 1.0.0 loaded
[ 0.588759] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
[ 0.589312] EISA: Probing bus 0 at eisa.0
[ 0.589345] EISA: Detected 0 cards.
[ 0.589350] cpuidle: using governor ladder
[ 0.589353] cpuidle: using governor menu
[ 0.589949] TCP cubic registered
[ 0.590143] NET: Registered protocol family 10
[ 0.590755] lo: Disabled Privacy Extensions
[ 0.591255] NET: Registered protocol family 17
[ 0.591319] Using IPI No-Shortcut mode
[ 0.591469] registered taskstats version 1
[ 0.591770] rtc_cmos 00:07: setting system clock to 2011-05-26 20:54:48 UTC (1306443288)
[ 0.591775] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 0.591779] EDD information not available.
[ 0.772356] ata1.00: ATA-5: IC25N040ATCS05-0, CS4OA63A, max UDMA/100
[ 0.772363] ata1.00: 78140160 sectors, multi 8: LBA
[ 0.772413] ata1.01: ATAPI: MATSHITA CD-RW/DVD-ROM UJDA740, 1.00, max UDMA/33
[ 0.787704] ata1.00: configured for UDMA/100
[ 0.843630] ata1.01: configured for UDMA/33
[ 0.930983] usb 2-1: new low speed USB device using uhci_hcd and address 2
[ 1.195783] isapnp: No Plug & Play device found
[ 1.196062] scsi 0:0:0:0: Direct-Access ATA IC25N040ATCS05-0 CS4O PQ: 0 ANSI: 5
[ 1.196329] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1.199882] scsi 0:0:1:0: CD-ROM MATSHITA CDRW/DVD UJDA740 1.00 PQ: 0 ANSI: 5
[ 1.203010] usb 2-1: configuration #1 chosen from 1 choice
[ 1.209201] sr0: scsi3-mmc drive: 24x/24x writer cd/rw xa/form2 cdda tray
[ 1.209210] Uniform CD-ROM driver Revision: 3.20
[ 1.209405] sr 0:0:1:0: Attached scsi CD-ROM sr0
[ 1.209524] sr 0:0:1:0: Attached scsi generic sg1 type 5
[ 1.209698] sd 0:0:0:0: [sda] 78140160 512-byte logical blocks: (40.0 GB/37.2 GiB)
[ 1.209779] sd 0:0:0:0: [sda] Write Protect is off
[ 1.209783] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.209824] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.210040] sda: sda1 sda2 < sda5 >
[ 1.259587] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.341635] Freeing initrd memory: 12827k freed
[ 1.366309] Freeing unused kernel memory: 620k freed
[ 1.367460] Write protecting the kernel text: 4540k
[ 1.367491] Write protecting the kernel read-only data: 1668k
[ 1.404719] udev: starting version 151
[ 1.805579] Linux agpgart interface v0.103
[ 1.839276] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/device:15/LNXVIDEO:00/input/input5
[ 1.839428] ACPI: Video Device [VID] (multi-head: yes rom: no post: no)
[ 1.861796] Floppy drive(s): fd0 is 1.44M
[ 1.862392] [drm] Initialized drm 1.1.0 20060810
[ 1.884468] FDC 0 is a post-1991 82077
[ 1.885792] agpgart-intel 0000:00:00.0: Intel 845G Chipset
[ 1.906326] 3c59x 0000:02:00.0: PCI INT A -> Link[LNKC] -> GSI 11 (level, low) -> IRQ 11
[ 1.906363] 3c59x: Donald Becker and others.
[ 1.906372] 0000:02:00.0: 3Com PCI 3c905C Tornado at e0804c00.
[ 1.929776] agpgart-intel 0000:00:00.0: AGP aperture is 64M @ 0xe8000000
[ 1.961913] usbcore: registered new interface driver hiddev
[ 1.969449] ohci1394 0000:02:01.2: PCI INT A -> Link[LNKD] -> GSI 11 (level, low) -> IRQ 11
[ 1.991956] input: Logitech Optical USB Mouse as /devices/pci0000:00/0000:00:1d.2/usb2/2-1/2-1:1.0/input/input6
[ 1.992223] generic-usb 0003:046D:C016.0001: input,hidraw0: USB HID v1.10 Mouse [Logitech Optical USB Mouse] on usb-0000:00:1d.2-1/input0
[ 1.992280] usbcore: registered new interface driver usbhid
[ 1.992285] usbhid: v2.6:USB HID core driver
[ 1.996405] nouveau 0000:01:00.0: PCI INT A -> Link[LNKA] -> GSI 11 (level, low) -> IRQ 11
[ 2.007963] [drm] nouveau 0000:01:00.0: failed to evaluate _DSM: 5
[ 2.008382] [drm] nouveau 0000:01:00.0: Detected an NV10 generation card (0x017400a5)
[ 2.008474] [drm] nouveau 0000:01:00.0: Attempting to load BIOS image from PROM
[ 2.156018] [drm] nouveau 0000:01:00.0: ... appears to be valid
[ 2.156160] [drm] nouveau 0000:01:00.0: BMP BIOS found
[ 2.156164] [drm] nouveau 0000:01:00.0: BMP version 5.21
[ 2.156168] [drm] nouveau 0000:01:00.0: Bios version 04.17.00.55
[ 2.156173] [drm] nouveau 0000:01:00.0: Found Display Configuration Block version 2.0
[ 2.156178] [drm] nouveau 0000:01:00.0: Raw DCB entry 0: 03000223 00000004
[ 2.156184] [drm] nouveau 0000:01:00.0: Raw DCB entry 1: 01010100 000088b8
[ 2.156187] [drm] nouveau 0000:01:00.0: Raw DCB entry 2: 020203f1 00000003
[ 2.156297] [drm] nouveau 0000:01:00.0: Loading NV17 power sequencing microcode
[ 2.156302] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 0 at offset 0xCDF4
[ 2.156343] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 1 at offset 0xD13A
[ 2.157598] ohci1394: fw-host0: OHCI-1394 1.0 (PCI): IRQ=[11] MMIO=[f8fff000-f8fff7ff] Max Packet=[2048] IR/IT contexts=[4/4]
[ 2.212036] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 2 at offset 0xCF0F
[ 2.212081] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 3 at offset 0xD6C9
[ 2.212092] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 4 at offset 0xD096
[ 2.212105] [drm] nouveau 0000:01:00.0: BIOS FP mode: 1600x1200 (162000kHz pixel clock)
[ 2.224533] [TTM] Zone kernel: Available graphics memory: 254670 kiB.
[ 2.224551] [drm] nouveau 0000:01:00.0: 32 MiB VRAM
[ 2.224634] agpgart-intel 0000:00:00.0: AGP 2.0 bridge
[ 2.224658] agpgart-intel 0000:00:00.0: putting AGP V2 device into 4x mode
[ 2.224686] nouveau 0000:01:00.0: putting AGP V2 device into 4x mode
[ 2.224718] [drm] nouveau 0000:01:00.0: 64 MiB GART (aperture)
[ 2.224990] [drm] nouveau 0000:01:00.0: Allocating FIFO number 0
[ 2.225565] [drm] nouveau 0000:01:00.0: nouveau_channel_alloc: initialised FIFO 0
[ 2.225579] [drm] nouveau 0000:01:00.0: Initial CRTC_OWNER is 0
[ 2.225588] [drm] nouveau 0000:01:00.0: Saving VGA fonts
[ 2.277719] [drm] nouveau 0000:01:00.0: Detected a LVDS connector
[ 2.378110] [drm] nouveau 0000:01:00.0: Detected a VGA connector
[ 2.378294] [drm] nouveau 0000:01:00.0: Detected a TV connector
[ 2.380158] [drm] nouveau 0000:01:00.0: Setting dpms mode 3 on lvds encoder (output 0)
[ 2.380165] [drm] nouveau 0000:01:00.0: Calling LVDS script 1:
[ 2.380170] [drm] nouveau 0000:01:00.0: Calling LVDS script 6:
[ 2.380175] [drm] nouveau 0000:01:00.0: 0xE480: Parsing digital output script table
[ 2.896033] [drm] nouveau 0000:01:00.0: Setting dpms mode 3 on vga encoder (output 1)
[ 2.896041] [drm] nouveau 0000:01:00.0: Setting dpms mode 3 on TV encoder (output 2)
[ 3.048355] [drm] nouveau 0000:01:00.0: allocated 1600x1200 fb: 0x49000, bo dd4e7000
[ 3.048582] fb0: nouveaufb frame buffer device
[ 3.048586] registered panic notifier
[ 3.048596] [drm] Initialized nouveau 0.0.15 20090420 for 0000:01:00.0 on minor 0
[ 3.052710] vga16fb: initializing
[ 3.052719] vga16fb: mapped to 0xc00a0000
[ 3.052727] vga16fb: not registering due to another framebuffer present
[ 3.089805] [drm] nouveau 0000:01:00.0: Setting dpms mode 0 on vga encoder (output 1)
[ 3.089812] [drm] nouveau 0000:01:00.0: Output VGA-1 is running on CRTC 0 using output A
[ 3.211290] [drm] nouveau 0000:01:00.0: Output LVDS-1 is running on CRTC 1 using output A
[ 3.211296] [drm] nouveau 0000:01:00.0: Calling LVDS script 2:
[ 3.211301] [drm] nouveau 0000:01:00.0: 0xE517: Parsing digital output script table
[ 3.248074] [drm] nouveau 0000:01:00.0: Setting dpms mode 0 on lvds encoder (output 0)
[ 3.248078] [drm] nouveau 0000:01:00.0: Calling LVDS script 5:
[ 3.248082] [drm] nouveau 0000:01:00.0: 0xE41A: Parsing digital output script table
[ 3.248097] [drm] nouveau 0000:01:00.0: Output LVDS-1 is running on CRTC 1 using output A
[ 3.251841] Console: switching to colour frame buffer device 160x64
[ 3.484253] ieee1394: Host added: ID:BUS[0-00:1023] GUID[474fc00007a3d041]
[ 3.660971] xor: automatically using best checksumming function: pIII_sse
[ 3.680022] pIII_sse : 3121.000 MB/sec
[ 3.680026] xor: using function: pIII_sse (3121.000 MB/sec)
[ 3.685290] device-mapper: dm-raid45: initialized v0.2594b
[ 3.869186] EXT4-fs (sda1): mounted filesystem with ordered data mode
[ 22.149959] Adding 1490936k swap on /dev/sda5. Priority:-1 extents:1 across:1490936k
[ 22.206089] udev: starting version 151
[ 22.291299] lp: driver loaded but no devices found
[ 22.424409] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 22.449973] Intel 82802 RNG detected
[ 23.100640] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[ 23.103254] dell-wmi: No known WMI GUID found
[ 23.104363] yenta_cardbus 0000:02:01.0: CardBus bridge found [1028:00d5]
[ 23.104387] yenta_cardbus 0000:02:01.0: Using CSCINT to route CSC interrupts to PCI
[ 23.104391] yenta_cardbus 0000:02:01.0: Routing CardBus interrupts to PCI
[ 23.104399] yenta_cardbus 0000:02:01.0: TI: mfunc 0x05033002, devctl 0x64
[ 23.247775] type=1505 audit(1306461311.152:2): operation="profile_load" pid=610 name="/sbin/dhclient3"
[ 23.248602] type=1505 audit(1306461311.156:3): operation="profile_load" pid=610 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 23.248998] type=1505 audit(1306461311.156:4): operation="profile_load" pid=610 name="/usr/lib/connman/scripts/dhclient-script"
[ 23.336821] yenta_cardbus 0000:02:01.0: ISA IRQ mask 0x0438, PCI irq 11
[ 23.336829] yenta_cardbus 0000:02:01.0: Socket status: 30000006
[ 23.336843] yenta_cardbus 0000:02:01.0: pcmcia: parent PCI bridge I/O window: 0xe000 - 0xffff
[ 23.336849] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xe000-0xffff: clean.
[ 23.338207] yenta_cardbus 0000:02:01.0: pcmcia: parent PCI bridge Memory window: 0xf4000000 - 0xfbffffff
[ 23.338212] yenta_cardbus 0000:02:01.0: pcmcia: parent PCI bridge Memory window: 0x20000000 - 0x29ffffff
[ 23.354287] yenta_cardbus 0000:02:01.1: CardBus bridge found [1028:00d5]
[ 23.354310] yenta_cardbus 0000:02:01.1: Using CSCINT to route CSC interrupts to PCI
[ 23.354314] yenta_cardbus 0000:02:01.1: Routing CardBus interrupts to PCI
[ 23.354322] yenta_cardbus 0000:02:01.1: TI: mfunc 0x05033002, devctl 0x64
[ 23.467257] input: DualPoint Stick as /devices/platform/i8042/serio1/input/input7
[ 23.494614] input: AlpsPS/2 ALPS DualPoint TouchPad as /devices/platform/i8042/serio1/input/input8
[ 23.594803] yenta_cardbus 0000:02:01.1: ISA IRQ mask 0x0438, PCI irq 11
[ 23.594810] yenta_cardbus 0000:02:01.1: Socket status: 30000006
[ 23.594822] yenta_cardbus 0000:02:01.1: pcmcia: parent PCI bridge I/O window: 0xe000 - 0xffff
[ 23.594829] pcmcia_socket pcmcia_socket1: cs: IO port probe 0xe000-0xffff: clean.
[ 23.596338] yenta_cardbus 0000:02:01.1: pcmcia: parent PCI bridge Memory window: 0xf4000000 - 0xfbffffff
[ 23.596343] yenta_cardbus 0000:02:01.1: pcmcia: parent PCI bridge Memory window: 0x20000000 - 0x29ffffff
[ 23.726491] Intel ICH 0000:00:1f.5: PCI INT B -> Link[LNKB] -> GSI 7 (level, low) -> IRQ 7
[ 23.726519] Intel ICH 0000:00:1f.5: setting latency timer to 64
[ 23.883735] type=1505 audit(1306461311.788:5): operation="profile_load" pid=759 name="/usr/share/gdm/guest-session/Xsession"
[ 23.940654] type=1505 audit(1306461311.848:6): operation="profile_replace" pid=761 name="/sbin/dhclient3"
[ 23.941383] type=1505 audit(1306461311.848:7): operation="profile_replace" pid=761 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 23.941790] type=1505 audit(1306461311.848:8): operation="profile_replace" pid=761 name="/usr/lib/connman/scripts/dhclient-script"
[ 23.994765] eth0: setting full-duplex.
[ 24.041299] type=1505 audit(1306461311.948:9): operation="profile_load" pid=763 name="/usr/bin/evince"
[ 24.107542] type=1505 audit(1306461312.012:10): operation="profile_load" pid=763 name="/usr/bin/evince-previewer"
[ 24.154877] type=1505 audit(1306461312.060:11): operation="profile_load" pid=763 name="/usr/bin/evince-thumbnailer"
[ 24.229304] pcmcia_socket pcmcia_socket1: cs: IO port probe 0x100-0x3af: clean.
[ 24.230503] pcmcia_socket pcmcia_socket1: cs: IO port probe 0x3e0-0x4ff: clean.
[ 24.231013] pcmcia_socket pcmcia_socket1: cs: IO port probe 0x820-0x8ff: clean.
[ 24.231087] pcmcia_socket pcmcia_socket1: cs: IO port probe 0xc00-0xcf7: clean.
[ 24.231725] pcmcia_socket pcmcia_socket1: cs: IO port probe 0xa00-0xaff: clean.
[ 24.233182] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x100-0x3af: clean.
[ 24.234385] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x3e0-0x4ff: clean.
[ 24.234895] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x820-0x8ff: clean.
[ 24.234968] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xc00-0xcf7: clean.
[ 24.235608] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xa00-0xaff: clean.
[ 24.556147] intel8x0_measure_ac97_clock: measured 53156 usecs (2554 samples)
[ 24.556153] intel8x0: clocking to 48000
[ 24.829009] ppdev: user-space parallel port driver
[ 25.018937] [drm] nouveau 0000:01:00.0: Allocating FIFO number 1
[ 25.020998] [drm] nouveau 0000:01:00.0: nouveau_channel_alloc: initialised FIFO 1
[ 25.091120] [drm] nouveau 0000:01:00.0: Setting dpms mode 3 on lvds encoder (output 0)
[ 25.091129] [drm] nouveau 0000:01:00.0: Calling LVDS script 6:
[ 25.091135] [drm] nouveau 0000:01:00.0: 0xE480: Parsing digital output script table
[ 25.639606] [drm] nouveau 0000:01:00.0: Output LVDS-1 is running on CRTC 1 using output A
[ 25.639612] [drm] nouveau 0000:01:00.0: Calling LVDS script 2:
[ 25.639617] [drm] nouveau 0000:01:00.0: 0xE517: Parsing digital output script table
[ 25.676065] [drm] nouveau 0000:01:00.0: Setting dpms mode 0 on lvds encoder (output 0)
[ 25.676071] [drm] nouveau 0000:01:00.0: Calling LVDS script 5:
[ 25.676075] [drm] nouveau 0000:01:00.0: 0xE41A: Parsing digital output script table
[ 25.676092] [drm] nouveau 0000:01:00.0: Output LVDS-1 is running on CRTC 1 using output A
[ 34.256025] eth0: no IPv6 routers present
[ 411.260802] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 510.986909] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
Thank you for replying.
jimmyservo
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_SCRIPT_DIR=
EMC2_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
EMC2 - 2.4.6
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=halui
DISPLAY=axis
NML_FILE=
Starting EMC2...
Cleanup done
1976
jimmyservo
- Thank you received: 4995
27 May 2011 12:00 #10112
Replied by andypugh on topic Re:Axis Simulator opens with realtime error
jimmyservo wrote:
Have a look at www.linuxcnc.org/component/option,com_ku...8/lang,english/#4205
