Font size in Axis code window
- TarHeelTom
I need to increase the font size for the code window at the bottom of the axis screen.
How far into the code abyss does one need to dig to find the place where the font size and face are specified? Does this require a complete new compile? Or do I need to just look for a 72" plasma monitor for the mill?
Tom
- Thank you received: 4995
I found myself in a similar situation with Touchy. it turned out that the solution was wierd, I needed to change the DPI setting in the "Appearance" settings of the desktop. It took a bit of drilling down into advanced settings to find it.
Alternatively, I suspect that a change to line 1507 in axis.tcl might do the trick:
git.linuxcnc.org/gitweb?p=emc2.git;a=blo...f435637a022efd6d8d0d
I _think_ that tcl is interpreted at run time, so you might not need to recompile. I don't know where that file lives in an installed system.
- ArcEye
- Thank you received: 758
Ditto re the default faint and small font - I dislike it.
The file lives at /usr/share/axis/tcl in an installed sytem or at ..../emc-dev/share/axis/tcl in a run-in-place system
Unfortunately that -height parameter actually controls the height of the g-code window, not the font.
God knows what units it is using, I didn't notice what was happening until I changed it to 24
However, sheer bloody-mindedness pays off.
I know squat about python, tcl etc. but after trawling through all the code I noticed that all the widgets seem to have a property -font
If you change the declaration around the line 1507ish area that Andy pointed out to:-
text ${pane_bottom}.t.text \
-borderwidth 0 \
-exportselection 0 \
-height 9 \
-font 24 \
-highlightthickness 0 \
-relief flat \
-takefocus 0 \
-yscrollcommand
${pane_bottom}.t.text insert end {}
you will get a nice big bold font in the g-code text box next time you start emc
I am going to change all my computers to this now!
- dgarrett
- Thank you received: 325
with a single command like this:
root_window.tk.call(".pane.bottom.t.text","configure","-font","Helvetica 20")
in this example, 20 is the font size
- ArcEye
It's the ideal solution, saves repeating the hack every time you upgrade, but I can't get it to work.
Under 2.4.6 it does nothing at all
Under 2.6pre it does enlarge and darken the font but in no relation to the size entered.
I tried 48 for the size and it was not noticeably larger than 24, which in turn was not greatly bigger than the default.
Strange when just entering -font 24 in the .tcl file has a huge effect.
Any ideas
- dgarrett
root_window.tk.call(".bottom.t.text","configure","-font","Helvetica 20")
or for a monospace font:
root_window.tk.call(".bottom.t.text","configure","-font","Courier 20")
- ArcEye
nothing in 2.4.6 and just darker and a little bit larger in 2.6 regardless of the font size passed
Very strange
- TarHeelTom
I finally found a subject that ALL the old farts can agree on.
And I thank the developers for leaving so many of these settings available to be changed, rather than casting all the settings in stone.
I'll dig into this later in the day and see what I can find.
Thanks for the quick response.
One other advantage of GNU software, the support team is awake 24/7.
Tom
- TarHeelTom
It worked just fine.
I also copied this message thread to a file and put stuck it in the directory for future reference.
Tom
- TarHeelTom
At the bottom of the left pane in axis, there is a slider marked Max Velocity, or something similar. Mine is showing a max velocity of about 400 in per min.
Where is the setup for that slider? Have spent a couple of hours digging through the docs, but haven't found it. I'd thought it'd be in the .ini file, but can't locate it.
Tom
