Preview not moving to new zero point
- photomankc
- Thank you received: 4
21 Jun 2011 19:19 #10727
by photomankc
Preview not moving to new zero point was created by photomankc
Always prior to this when I would rezero an axis the path preview would snap to that new position for each change. Lately I have noticed that it randomly seems to not do this. I have to reload the file to get the preview to locate properly to new relative zero positions. Has anyone else run into that? A bug or something else. It doesn't seem to affect the actual machine movement, just the preview toolpath displayed on screen.
- photomankc
26 Jul 2011 15:26 #11872
by photomankc
Replied by photomankc on topic Re:Preview not moving to new zero point
Ignore this (as you already have)
- This issue is encountered when I use pyVCP or other HAL components to set the zero via MDI. The GUI doesn't know that it happened. Now that I use the control panel or pendant almost exclusively I realized the issue. I wasn't using the "Touch Off" buttons in Axis anymore. When you use those, the preview pops to the new location immediately.
Time to create page: 0.048 seconds
