Home all axes not working as expected on my setup
- alanb
I have reconfigured emc so that I have two alternative setups, either XYBU as axes or XYBV. This is because I have an independant cutter on the U or V axis and this reflects whether the cutter is directed along the X axis to cut perpendicular to the axis of rotation Y, or towards the Y axis for faceplate work. Everything works ok and the display is what I anticipate so no problem there.
However when I select home all axes only the X and Y axes are homed in either setup. I then have to manually home the B and U or V. Is this to be expected?
My ini file has
HOME_OFFSET = 0.0
HOME_SEQUENCE = 0
for all axes so I thought that the B and U V would be included in the sequence but they dont seem to be. So what do I have to add to the ini file to get them included?
thanks
Alan
- BigJohnT
- Thank you received: 1176
And it follows the instructions here?
www.linuxcnc.org/docview/html/config_ini_homing.html#r0_1_2
- alanb
All axes have Home_SEQUENCE = 0
- alanb
My ini file is
[EMC]
MACHINE = rose
DEBUG = 0
[DISPLAY]
DISPLAY = axis
GEOMETRY = B X Y U
EDITOR = gedit
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 1.2
INTRO_TIME = 5
PROGRAM_PREFIX = /home/alan/emc2/nc_files
INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm
PYVCP = custompanel.xml
USER_COMMAND_FILE = tkapp.py
TKAPP = ngcgui_app.tcl
NGCGUI = ngcgui.tcl
NGCGUI_FONT = Courier -10 normal
NGCGUI_PREAMBLE = /home/alan/emc2/nc_files/in_std.ngc
NGCGUI_SUBFILE = /home/alan/emc2/nc_files/slot.ngc
NGCGUI_SUBFILE = /home/alan/emc2/nc_files/simp.ngc
NGCGUI_SUBFILE = /home/alan/emc2/nc_files/iquad.ngc
NGCGUI_SUBFILE = /home/alan/emc2/nc_files/gosper.ngc
NGCGUI_OPTIONS = nonew noremove nonew
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = emc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
BASE_PERIOD = 100000
SERVO_PERIOD = 1000000
[HAL]
HALUI = halui
HALFILE = rose.hal
HALFILE = custom.hal
POSTGUI_HALFILE = custom_postgui.hal
[HALUI]
# add halui MDI commands here (max 64)
[TRAJ]
AXES = 9
COORDINATES = X Y U B
MAX_ANGULAR_VELOCITY = 60.00
DEFAULT_ANGULAR_VELOCITY = 6.00
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 5.00
MAX_LINEAR_VELOCITY = 30.00
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 10.0
MAX_ACCELERATION = 30.0
STEPGEN_MAXACCEL = 37.5
SCALE = 80.0
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -250.0
MAX_LIMIT = 250.0
HOME_OFFSET = 0.0
HOME_SEQUENCE = 0
[AXIS_1]
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 10.0
SCALE = 80.0
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -200.0
MAX_LIMIT = 200.0
HOME_OFFSET = 0.0
HOME_SEQUENCE = 0
[AXIS_2]
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 10.0
SCALE = 133.333333333
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -75.0
MAX_LIMIT = 75.0
HOME_OFFSET = 0.0
HOME_SEQUENCE = 1
[AXIS_3]
TYPE = ANGULAR
HOME = 0.0
MAX_VELOCITY = 360.0
MAX_ACCELERATION = 200.0
STEPGEN_MAXACCEL = 200.0
SCALE = 17.7777777778
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -9999.0
MAX_LIMIT = 9999.0
HOME_OFFSET = 0.0
HOME_SEQUENCE = 1
- BigJohnT
- Thank you received: 4995
My ini file is
[TRAJ]
AXES = 9
[AXIS_0]
[AXIS_1]
[AXIS_2]
[AXIS_3]
You need axis stanzas up to 7. The V axis is axis 7, which is an explicit link in the code.
You can configure the HAL to use axes 0 through 3 for the joint parameters, but other parts of EMC2 look in the iNI file too.
Axis velocity limits, home positions and home sequence need to be in the hard-coded sections
This explicit link between cartesian axes and joints is actively being removed in one of the development branches of EMC2
- alanb
Does this also apply to the B axis? I thought that the [AXIS 3] bit of my ini file was related to the B axis through COORDINATES. As this may answer another question I was about to ask. Even though I have changed
MAX_ANGULAR_VELOCITY to 3600.00 and DEFAULT_ANGULAR_VELOCITY to 600.00 in TRAJ and also MAX_VELOCITY and MAX_ACCELERATION in the stanza? for [AXIS_3] these values havent made any difference. My machine still rotates the spindle at about 1 degree per second and I was wondering what to do to rectify this. Is the answer to have entries for all axes 0 though 8 ? If so I may as well use the 9 axis ini file.
Alan
No, as far s I know (and it is possible that it has changed) all that COORDINATES does is alter what axes get displayed. It does not do any re-mapping of axis numbers to joints. (edit) It also defines which axis words are valid in the G-code.Does this also apply to the B axis? I thought that the [AXIS 3] bit of my ini file was related to the B axis through COORDINATES.
You can afford to leave the unused axes pretty much blank, but yes, the speed and homing for the B axis will always come from [AXIS_4]
- alanb
I did this and now all is working fine.
Alan
