Axis log
- Andinc
17 Aug 2011 20:22 #12553
by Andinc
Axis log was created by Andinc
Hello,
is there a way to log the name and time of a loaded nc file?
Also the time when the manual tool change pops up and when the program is started again.
Andy
Andy
- ArcEye
- Thank you received: 758
18 Aug 2011 10:05 #12573
by ArcEye
Replied by ArcEye on topic Re:Axis log
Hi
You don't say why you ask, can only assume for job estimating or logging.
see
www.linuxcnc.org/index.php?option=com_ku...start=0&lang=russian
as a starter (don't worry its not in russian)
I know there have been other discussions but can't trace them at present.
Beyond that it would be entirely possible to log events, by inserting code into the Axis code ( and even the toolchanger component if that is really relevant ) to trigger timestamps, depends upon your programming skills.
Another way would be to set up a M1xx file which timestamps a log file, along with a descriptor of the event being logged and insert it into your gcode at the relevant junctures.
see
- ArcEye
18 Aug 2011 14:08 #12583
by ArcEye
Hi again
The below is an example of what I described regards using a M1xx routine, you can add to and adapt it as you wish.
M120 below takes the 1st parameter passed (P), converts to int from float and switches that value to the appropriate subroutine.
The subroutine prints the reason for logging to file along with a date/time stamp.
You just need to write a .ngc file that has entries like
M120 P1
G80 G90 G94
G21 G18 G7
G40
......... Do stuff
M120 P2
M6T2
M120 P3
...........Do stuff
M2
M30
M120 P4
You will of course have to 'chmod 0755 M120' to make it executable, place it in the directory pointed to by PROGRAM_PREFIX etc
(see docs for using user defined M codes)
It will produce an output like this in logfile
Started machining
Thu Aug 18 14:47:47 BST 2011
Toolchange started
Thu Aug 18 14:48:31 BST 2011
Toolchange ended
Thu Aug 18 14:48:37 BST 2011
Stopped machining
Thu Aug 18 14:48:43 BST 2011
M120 P1
G80 G90 G94
G21 G18 G7
G40
......... Do stuff
M120 P2
M6T2
M120 P3
...........Do stuff
M2
M30
M120 P4
Started machining
Toolchange started
Toolchange ended
Stopped machining
#!/bin/bash
## writes a log based upon gcode calls to M120 n
## where n = the occurence to be logged
if [ ! $# -ge 1 ]; then
echo "Usage: M120 n - where n log entry type num"
exit 1
fi
float=$1
int=${float/\.*}
case $int in
1 ) echo "Started machining" > ~/emc2/logfile
date >> ~/emc2/logfile;;
2 ) echo "Toolchange started" >> ~/emc2/logfile
3 ) echo "Toolchange ended" >> ~/emc2/logfile
4 ) echo "Stopped machining" >> ~/emc2/logfile
esac
exit 0
The following user(s) said Thank You: +Jan+
Time to create page: 0.060 seconds
