Image-to-gcode python issues
- fritzgutten
12 Dec 2009 02:44 #1304
by fritzgutten
Image-to-gcode python issues was created by fritzgutten
Greetings, not sure if this is the proper place to post about this part of emc, or even if i should be posting about it to the emc forums.
I've been using emc2 for a couple of years now and recently have been trying to use the image-to-gcode program to create a project.
My issue is that there appears to be an issue with python? and i get an error :
fred@cnc1:~/Desktop$ image-to-gcode Alison01.jpg > Alison0102.ngc
File "/usr/bin/image-to-gcode", line 818, in ?
main()
File "/usr/bin/image-to-gcode", line 780, in main
nim1[tw:tw+w, th:th+w] = nim
File "/usr/lib/python2.4/site-packages/numarray/generic.py", line 618, in _broadcast
return _broadcast(arr, self._shape)
File "/usr/lib/python2.4/site-packages/numarray/generic.py", line 93, in _broadcast
raise ValueError("Arrays have incompatible shapes")
ValueError: Arrays have incompatible shapes
is there any solution to this issue? i'm a bit lost, i've tried installing the latest version of emc on 8.04 ubuntu as well as upgrading emc on 6.04 and the issue persists. oddly enough, running on the live cd there seems to be no issues.
thanks for any pointers you can give.
main()
- fritzgutten
13 Dec 2009 01:47 #1306
by fritzgutten
Replied by fritzgutten on topic Re:Image-to-gcode python issues
well, i've gone through a bunch of testing, seeing as how image-to-gcode seemed to run just fine off the live cd.
after multiple installs I've "discovered" that i can get it to run if i do a fresh install and disable/or just dont update the distro. i also have to avoid using the ...hmmm, extent image border? feature, this was throwing a similar error, with different error lines listed.
anyhow, thanks for looking. if anyone has further insight, i'd appreciate it.
- KenC
11 Nov 2010 07:50 #5210
by KenC
Replied by KenC on topic Re:Image-to-gcode python issues
I using 8.04LTS Live disc installation & facing the same problem too. Identical Error massage to the dot.
Had the [Filter] lines in my .ini
Tried reinstall & disable update but still show the same error massage.
Just wonder if this is a hardware compatible issue or is there something to do with configuration...
- BigJohnT
- Thank you received: 1176
11 Nov 2010 12:52 #5228
by BigJohnT
Replied by BigJohnT on topic Re:Image-to-gcode python issues
Do you have a link to the one your trying to use I'll check it out.
- KenC
15 Nov 2010 00:55 #5306
by KenC
Hi john,
I don't understand what link you are refering to, please direct me to show it to you, I'm total idiot when it comes to matters like these.
- BigJohnT
15 Nov 2010 12:41 #5317
by BigJohnT
I just did a search for "image to gcode" and came up with a few... then searching the manual I found that it is included with EMC. I'll try and run it here and see what I get.
- BigJohnT
15 Nov 2010 13:07 #5320
by BigJohnT
I have 10.04 installed and the Axis Sim is set up to run Image-to-gcode so I tried that. I had to set the pixels to 10 for the image I had loaded for it to complete.
Have you tried it with the Axis Sim or is this a Step Conif generated configuration?
- KenC
16 Nov 2010 07:51 #5328
by KenC
Thanks.
Time to create page: 0.083 seconds
