mpg without external button
- centipid
14 Sep 2011 23:52 #13204
by centipid
mpg without external button was created by centipid
I need help in using or configuring MPG without external push button(hardware), but instead use the GUI to select which axis to jog. I'm new to emc2 and I successfully configure my machine except for MPG. I don't want to use additional hardware(button) to select the axis, I just want to utilized the GUI for that function.
- Thank you received: 2162
15 Sep 2011 07:32 - 15 Sep 2011 07:43 #13209
Replied by cmorley on topic Re:mpg without external button
AXIS exports pins with names such as;
axisui.jog.x
That pin will be true when you select that axis in the GUI
You can connect that to (again for the X axis)
axis.0.jog-enable
then these
axis.0.jog-counts to an encoder counter
axis.0.jog-scale to axis.jog.increment
Some references (EMC 2.4.x:)
www.linuxcnc.org/docs/2.4/html/gui_axis....:Physical-jog-wheels
www.linuxcnc.org/docs/2.4/html/config_emc2hal.html
Hope that gives you the idea .
axisui.jog.x
axis.0.jog-enable
then these
Last edit: 15 Sep 2011 07:43 by cmorley.
- centipid
15 Sep 2011 15:55 #13213
by centipid
Replied by centipid on topic Re:mpg without external button
Thanks cmorley, I will try this tonight and will keep you updated.
- centipid
05 Oct 2011 00:42 #13661
by centipid
Hello Cmorley,
Sorry for the delay response. I tried what you said but it didn't work. Can you please send me a sample code that I can load and test?
05 Oct 2011 00:46 #13662
better if you zip your config files and post them.
I might add that i have not set up jogging as you have asked but it should not be a problem.
- centipid
05 Oct 2011 04:40 #13667
by centipid
Here you go Cmorley.
05 Oct 2011 04:51 #13669
looks like you connected
axisui.jog.a
axisui.jog.b
axisui.jog.c
instead of
axisui.jog.x
axisui.jog.y
axisui.jog.z
axisui.jog.a
axisui.jog.b
axisui.jog.c
instead of
axisui.jog.x
axisui.jog.y
axisui.jog.z
- centipid
10 Oct 2011 17:24 #13811
by centipid
It works!!!! Thanks for your help, Cmorley.
10 Oct 2011 19:21 #13812
you are very welcome
Time to create page: 0.075 seconds
