A axis display
- tymcneer
Now... I have this little, but annoying issue with the display. The display acts as though the head is revolving around the stock, rather than the head being fixed and the stock revolving.
Is there any way to change the display, so that I am not drilling and milling from the inside of my work piece?
If not, this will not upset me, it just looks odd, and makes debugging handwritten gcode a touch more difficult.
Thanks in advance for any and all help,
Ty
- Rick G
- Thank you received: 155
GEOMETRY = XYZABCUVW
Controls the preview and backplot of rotary motion. This item consists of a sequence of axis letters, optionally preceded by a "-" sign. Only axes defined in [TRAJ]AXES should be used. This sequence specifies the order in which the effect of each axis is applied, with a "-" inverting the sense of the rotation.
The proper GEOMETRY string depends on the machine configuration and the kinematics used to control it. The example string GEOMETRY=XYZBCUVW is for a 5-axis machine where kinematics causes UVW to move in the coordinate system of the tool and XYZ to move in the coordinate system of the material. The order of the letters is important, because it expresses the order in which the different transformations are applied. For example rotating around C then B is different than rotating around B then C. Geometry has no effect without a rotary axis.
This can change the display, but with AXIS it is normal for the tool to move on the display, not the work.
Rick G
- tymcneer
I take it you have worked with the geometry statement in your .ini file.
Rick G
I believe I had looke into the information you quoted, but as you stated, I don't think it made any difference on the display
Rick, thanks for the information. I kinda expected that to be the answer, but I was so hoping I had missed something simple.
Ty
- elvistaylor
- Visitor
www.emd-usa.com/
