reload program through pin
- strykerg
05 Nov 2011 12:16 #14591
by strykerg
reload program through pin was created by strykerg
is it possible to reload the current program through a hal pin?
i'm building a sort of pendant which includes a button for touching off the current axis. the touch-off works however unless the program is reloaded the backplot does not reflect the offset properly. and the only solution I found is to reload program (I guess that's what the touchoff button in axis does?)
or is there some other way to update the backplot?
thanks
thanks
- Thank you received: 4995
05 Nov 2011 22:18 #14598
Replied by andypugh on topic Re:reload program through pin
linuxcnc.org/docs/html/man/man1/axis-remote.1.html
Looks like one way. You probably need to make a pin call an MDI_COMMAND that calls a M101 custom-G-code that runs a script that calls axis-remote.
So, it's a bit of a long-winded kludge.
I think that GladeVCP allows you to link actions direct to controls, which is a bit more elegant.
- strykerg
06 Nov 2011 02:51 #14601
by strykerg
Replied by strykerg on topic Re:reload program through pin
looks like its not that simple. ill have a deeper look into this, at least now i know what i'm looking for. will feedback once i get some reaults (or get stuck somewhere
Time to create page: 0.063 seconds
