Python Version On AXIS
23 Jan 2012 17:17 #17060 by BigJohnT
Replied by BigJohnT on topic Re:Python Version On AXIS
grokhehe wrote:
Yes, I've already followed the instructions but
tkapp.py (2.4 only) => Can't find this file on zipped file
ngcgui_app.tcl => Can't find this file on zipped file
ngcgui.tcl
ngcgui_ttt.tcl
I'm using EMC 2.4.3
What download link did you use?
23 Jan 2012 17:42 #17062 by ArcEye
Replied by ArcEye on topic Re:Python Version On AXIS
Could you please show me sample code to do that?
Has been covered before, see
www.linuxcnc.org/index.php/english/compo...imit=6&start=6#10576
And please provide me with simple G-Code like drawing line after clear the AXIS preview frame
Not sure what you mean by this
M123 (clear axis plot)
G00 X200
23 Jan 2012 18:19 #17064 by grokhehe
Replied by grokhehe on topic Re:Python Version On AXIS
I've already do on that link that you've gave me but it didn't work
I want to clear the text "EMC2.4 AXIS" on AXIS preview frame because it annoying..
Could you please help me?
24 Jan 2012 00:29 #17072 by BigJohnT
That is easy, just don't load the file on startup the setting is in your [DISPLAY] section of the ini file.
24 Jan 2012 03:26 #17078 by grokhehe
Thanks for help,
But what I mean is can I clear the AXIS preview frame every time I click the pyvcp button and run the G-Code file with M Command?
I already try on ArcEye's answer but it didn't work..
24 Jan 2012 03:59 #17080 by grokhehe
Example like when you open the file ngc from File -> Open File, AXIS will cleart the preview frame and then draw your ngc file
Can I do like that with pyvcp command M Command?
24 Jan 2012 05:39 #17083 by grokhehe
ArcEye, could you please send me a file that can do that?
With axis-remote -c/
24 Jan 2012 06:09 #17084 by grokhehe
G00 X200
Yes I want to do like that, after I clear axis plot then I want to run G-Code
Could you please send me a file?
24 Jan 2012 09:07 #17086 by ArcEye
It does work, I use dozens of similar files on my system.
You need to read the whole thread which contains all the things that have to be in place for user M codes to work.
If you say specifically what you have done and what the error message is you get, or what result, I could help, but just saying it does not work, gets nowhere.
could you please send me a file that can do that? With axis-remote -c
There is already a zip on that thread with a M code file in it. And code to clear the display is in the text of one of the posts.
How you use it in your g code is up to you.
24 Jan 2012 09:12 #17087 by grokhehe
So can I use like this :
file : O101.ngc
#!/bin/bash
axis-remote -c
G0 X0.0
G0 X100.0
can it work?
Time to create page: 0.073 seconds
